Charlie_Zhan
- Nov 17, 2013
but definitely no issues syncing contacts and messages.China rom don't have access to location history
not true.. just need to give permission and set it up correctly..
Nfc need nfc sim card to work for taking bus and mrt right?
No change to such sim card,nfc also no point?
No need. Using a normal sim card with singtel dash for transport no issuesNfc need nfc sim card to work for taking bus and mrt right?
huh nfc got need nfc sim card one meh? got such thing anot?
most likely no need. I've never gotten any special "nfc" sim card and nfc functionality works fine on my two phones, even google pay for bus and mrt.
Sent from Xiaomi MI 9T PRO using GAGT
Yes, of course you need to have $$ in the app's virtual Visa card as wellOh download the app
Then on nfc will do?
Oh download the app
that was many many years ago when there was no simplygo.. nowadays I think telcos stop issuing NFC Sim cards already.. but mine is still a NFC Sim card.. and I also don't use its ezlink function anymore.I read from ezlink leh
How u activate your nfc to use ezlink to take mrt etc
Have u tried Google map to see if it works?
Can also try reset GPS with GPS status apps
Yes I did. All my apps that require GPS will have this issue.
If you did all the checks, and gps is still not working, perhaps your set is a lemon
After Apple, now new brand is Lemon
Anyone using the Note 8 to play POGO? Getting the phone for parent who plays a lot of POGO so making sure it will work before buying.
Sent from Samsung SM-N970F using GAGT
