Redmi Note 8
Charlie_Zhan
oic thanks! but i couldn't even find netflix in google play. when i install manually, netflix apk says device not supported by apps?!
because device/rom/region not whitelisted by Netflix
chesterqw
For those with global model, don't worry first, the redmi note 7 global also didn't have HD Netflix until like in a future firmware uodate
rrr2015
oic thanks … and i was under impression that others managed to get Netflix working on their note 8. LOL
anyway not important, don't watch on mobile as i use my tablet for watching netflix
got note 8 6gb+128gb China rom. installing Google services + play goes smoothly. will be testing more local apps during weekends
winderen
Does ur gps has issue? Mine got.
Charlie_Zhan
yeap same as poco.. initially no hd Netflix but eventually got it..
what kind of issues? mine so far still ok
ccmheoa
To be precise u can still do backup but not complete, eg only contacts and photos
can those bloatware be disabled? or you need root or adb to remove them?
you mean we can't install & use Google backup on China rom phones?
chesterqw
Apps that require gps can't detect ur location. E.g grab, foodpanda
No problem on my device, the location setting you set to high accuracy which uses GPS, WiFi, Bluetooth, and mobile network?
As well as got allow the app to use location?
Side note anyone tried Spotify but have problems with the second menu; the 3 dots one like selecting the song radio, not the gear one. It hangs there and stop responding :'(
rrr2015
I can't restore & sync Google contacts.
Contacts wasn't even in Google sync
Any ideas?
Charlie_Zhan
When you assume people will do all the checks first by themselves :x
it was already mentioned in the step by step YouTube video someone posted earlier on.. and just correcting your assumption of "China ROM don't have access to all of Google's stuff or something"
bockers
China rom don't have access to location history
