Redmi Note 8
Broadwalk
Good value but it’s 665 soc right but if don’t need powerhouse and / or gaming very good daily spare driver
Btw the redmi note 8 Pro you get is from the store? :o So if I visit the store and get, will price cheaper than online? :o
Teo Ming Ern
Xiaomi online and Xiaomi physical store? Shouldn't the price be the same? Unless you're buying the China ROM version then I think online non-Xiaomi sellers still the cheapest...
TechNo0B
Hi, anyone using export set RMN8Pro with china ROM? Asking as I would like to know if there is any major differences & any restrictions on using apps or functions of phone, e.g NFC function. Also is it possible to get Global ROM on it? TIA.
No one can help answer? I hv an export set with CN ROM, cant seem to install Netflix via Google playstore, states "device isnt compatible with this version"... 🙄😣😫
Broadwalk
I am referring to getting the global rom , buy from the store directly cheaper or same or more expensive than getting from shopee, lazada or q10. :o
Just Me
No one can help answer? I hv an export set with CN ROM, cant seem to install Netflix via Google playstore, states "device isnt compatible with this version"... ���
Just install a 3rd party app store like apkpure to install it.
Sent from Xiaomi MI 9T PRO using GAGT
davidwong
Yes from the store direct and no no discount hence if not in a hurry to get can get online and self collect
NightRaven49
https://forums.hardwarezone.com.sg/.../redmi-note-8-a-6098621-10.html#post123147653
one more thing is the widevine certification, which is not l1 for export set, so even if u can install netflix, u cannot watch hd videos. nfc will work fine so long as not gpay (as detailed in link).
Broadwalk
At the time I check 14 OCT it’s 335 for 128 GB note 8 pro but you can use any coupon you have to off set , at the store is just 335
I presume you refer to shopee or lazada? :o I went q10 it is more than 335. :o
tanchinkoo
yes..
Sent from Xiaomi REDMI NOTE 8 using GAGT
thanks !!!
tanchinkoo
U go to (get apps)
search netflix
then click on the .豌豆菜
small green half moon logo.
Charlie_Zhan
yes sd 665.. for $188 I can't complain.. I'm just using it as spare phone..
chesterqw
MIUI 11
Phase 3: November 13 - 29
Redmi Note 6 Pro
Redmi 7A
Redmi 8
Redmi 8A
Redmi Note 8
Phase 4: December 18 - 26
Redmi Note 8 Pro
