Redmi Note 8
Charlie_Zhan
Bro
Ask you Simi model Simi ROM, not ask you show me developer option.
Original ROM is global or ownself flash?
CN set so ownself flash global rom
Sent from Xiaomi REDMI NOTE 8 using GAGT
Pocoyoz
China review compare redmi note 8 pro to honor 9x.
G90t Laoya, will drop frame :(
Broadwalk
Any one knows any mi shop or any place has the redmi note 8 pro set to feel and see? :o
Broadwalk
I have done some research. Found out :
1. Redmi Note 8 - SIM tray is 2 x SIM + microSD slot
2. Redmi Note 8 Pro - Dual SIM hybrid microSD slot
From various review, all say that Redmi Note 8 Pro camera is not that good.
Anybody got Redmi Note 8 Pro yet?
What is Dual SIM hybrid microSD slot? :o Can enlighten me or not? :o
Broadwalk
Means either can put :
2 x Nano SIM
OR
1 x Nano SIM and 1 x micro SD card
So if I need dual sim function I will need to forgo the SD card storage? :o For default unit for redmi 8 pro do they give us free SD card? :o
i1magic
Yes. By right yes. Currently, I am using this on my Mi Max 3, which allows me to use 2 x Nano SIM + microSD card.
Broadwalk
Is this extender available for Redmi note 8 pro?:o I am using two SIM cards and I think I need sd memory because I need it as a video cam when I drive taxi.:o
i1magic
I will later go around and see when I park my taxi for break and search mi shop. :o Last I went JEM they dun have yet. :o
Just went Mi shop at Bedok Mall, they selling both White and Green Redmi Note 8 Pro.
Charlie_Zhan
Dang, probably you ownself flash de ROM was more complete compared to the official one.
I flashed the official global rom downloaded from Xiaomi. the same one that is on global sets.
Charlie_Zhan
