Redmi Note 8
DenOOO
Just checked the website
Where got buy from shop one, cannot use discount cannot coupon and all.
Of course buy from Qoo10 and use coupons ma.
Actual price paid will be even lower if factor in discount from purchasing gift cards and qcoins.
NightRaven49
9T is the one with the movable camera - up and down, right ? For me, I worry I may damage it or it spoils over time. So I've not consider this phone.
But 9T 64GB only and its non expandable. Note 8 Pro can add microSD card.
Sent from Samsung SM-N970F using GAGT
9t 6/64gb $368 nia @rwm :eek:
Dunno which one to buy :(
Sent from Amazon using GAGT
if modding your phone like rooting or flashing custom rom is not important to u, note 8 pro is probably the better value proposition. sure u lose amoled and get a notch, but u get a faster processor, have sdcard slot and bigger battery, all for cheaper.
TechNo0B
Can anyone advise if any shops does flashing of Global ROM for CN ROM set? Currently having 1 set on CN ROM, managed to install G.Play store and services but encountering some problems with some apps and GPS. If managed to flash to Global ROM will be totally same with local sets on Global ROM? Thks.
Charlie_Zhan
need to unlock your bootloader first before flashing.. so don't think shops will do for you.. ownself flash la.. it's not a difficult process.. I just received a new global OTA update and it went through smoothly without issue.
TechNo0B
Nvr done all these software thingy b4, quite unsure. U able to guide thru whole process? After flashing to global ROM, all apps working fine as per local global rom set? TIA
Charlie_Zhan
There are many step by step guides online.
Sent from Xiaomi REDMI NOTE 8 using GAGT
Pocoyoz
modding not impt, gaming too:s22:
nfc impt;)
T version just nice
