Redmi Note 8
AcquiT
Wah dont know what happened today
Google keep stopping message keep appeared
Try all clear data etc for google play etc also no use
TechNo0B
Nvr done all these software thingy b4, quite unsure. U able to guide thru whole process? After flashing to global ROM, all apps working fine as per local global rom set? TIA
Can anyone else assist on this? Thks.
rrr2015
What the message says? Suspect some permissions not set correctly
So far mine no problem
Recently updated to 10.3.8
i1magic
AcquiT
Mine global rom stable 10.4.5
Wierd
Last updated google service is 31/10 today
Then kana liao
NightRaven49
this forum already have another topic with instructions, just look harder. as for other things, cn set flashed with global rom will work 99% like global set, except apps that rely on safetynet, like google pay, snapchat, pokemon go and some banking apps like stanchart, they will not work properly. if u dont use these apps then should be fine. got way to circumvent this also, but not advisable if u unsure on how to do.
efreelancer
Can anyone advise if any shops does flashing of Global ROM for CN ROM set? Currently having 1 set on CN ROM, managed to install G.Play store and services but encountering some problems with some apps and GPS. If managed to flash to Global ROM will be totally same with local sets on Global ROM? Thks.
Just wondering how much you pay to go through the hassle. I know in Cn sell only $200+
efreelancer
Scb app wont work if use cn version? I used scb app a lot man.
NightRaven49
it will work so long as your bootloader is locked. however he was asking about installing global rom on cn set, which requires unlocked bl and will break safetynet.
rrr2015
Still trying to understand about Magisk, so is this installed after flashing to say china to global from? What about twrp? Is it necessary to to install after flashing to new rom? I understand this a recovery tool?
NightRaven49
yes u flash magisk after flashing global rom. twrp is an entirely different recovery which more powerful than stock, and is required in flashing magisk. however, it is not required permanently on the device, and u only need to temporarily boot it to flash magisk. anyway if u dont do any modification to miui it will overwrite twrp on every boot/update. not sure if n8p has a working twrp by now though.
bockers
