Redmi Note 8
efreelancer
This phone can work with TPG volte to make calls? And is there a way to toggle Singtel dash nfc and Google pay?
Shadow79
Hi guys, can I check with Note 8 owners, do you have call recording options in the settings in MIUI? I’m looking to buy the Note 8 for work purpose but I read conflicting reports. Some say have, some say don’t have (those on EU ROM). SG sets has the feature?
PeasantBeing
China set with China ROM has call recording. Global ROM does not have call recording.
Sent from REDMI NOTE 8 Neptune Blue using GAGT
i1magic
Saw this on AliExpress.
SG$ 26.53 34%OFF | 6500mAh Battery Charger Cases For Xiaomi Redmi Note 8 Pro Power Case Backup Power Bank Cover for Redmi Note 8 Pro Charging Case
https://s.click.aliexpress.com/e/m0wZRbZq
For those who need the longevity.
cscs3
Not true, global rom also has. After you dial the number, the option is there.
efreelancer
Tried, cannot support TPG VoLTE.
Thanks. I have the impression that TPG enable volte on certain brands they choose only. I tried with a China budget phone, circle has volte as an option but TPG the option is not even visible.
Not sure if all the listed Huawei handphone can make volte calls.
Even India more advanced than us sia.
Charlie_Zhan
tried.. doesn't have the recorder function..
refer to screenshot above.. the call is made with TPG Sim card inside..
Sent from Xiaomi REDMI NOTE 8 using GAGT
PeasantBeing
Show it.
Mine doesn't have after I flashed my China non pro set to Global ROM. I want it too.
Heng my old Note 5 still has it.
Sent from REDMI NOTE 5 Gold using GAGT
mankind66
My honor phone can call with tpg in sg but not in jb
Pocoyoz
Those who bought from shopee apex, has u received the phone?
Sent from Amazon using GAGT
AcquiT
Tpg can
Unlock it with the # code
I did this for mix 2,max 2 and note 8 pro
AcquiT
Btw who tried mute using power button but the screen will still pop up till caller end ah
I remembered power button can blank the screen till caller put down and wont keep pop up again one
Not end call function
cscs3
Show it.
Let me do a screen capture and upload. I am not using VoLTE. Mine is global out of box.
Mean while try this:
At left bottom 3x--- click and select setting. You will see recording option is off or on.
cscs3
Same for my case, Circles or Singtel get VoLTE but not TPG. The option is grey out.
PeasantBeing
Don't talk nonsense. The global rom is using Google phone app and not MIUI phone app. There is no call recording in Google phone app. Only MIUI phone app has call recording.
