Redmi Note 8
grapewall
anyone facing this issue or got solution to it? tried looking into alot of settings and also comparing to my k20 pro but to no avail.
when the screen is off, any incoming whatsapp call won't wake the screen up.
when the screen is on, any incoming whatsapp call notification is not in full screen.
On my REDMI note 7, i went to settings, notifications, whatsapp then turned on all the tabs.
bbcccc
anyone got the 11.0.3 ota update?
dotter de set pushed in le
mine stil on 11.0.2
Sent from Xiaomi REDMI NOTE 8 PRO using GAGT
sumantochong
Qoo10 never sell Note 8 Pro Global ROM version ah? I see only Lazada got sell only? Cheapest I seen for 6/64 $265 ... Worth it? Waiting for Lazada coupons, hopefully 3rd Jan got sale ...
eting72
Ocean blue or white nicer?
Sent from Amazon using GAGT
Sent from OnePlus HD1900 using GAGT
wongminmin
nope expensive.
most get it for $240+ for 128
later got promos, my guess is $250+
Pocoyoz
go shopee buy 6/128
$28 off $288 + $10 off dbs
$289-$38 = $251:yawn::s21: may have cheaper one
pat7471
First, make sure Whatsapp's "Auto-start" is enabled in Permissions.
Next, make sure the app is not on any battery saving mode.
If issue still persist, lock the app in memory so that it will not be cleared. To do this, make sure Whatsapp already running. Press the bottom menu key, press and hold Whatsapp and choose the lock icon.
Hope that helps.
yh_lee
I just got a 128 GB microsd card . I am able to save photos taken by camera to it by changing storage settings. However,I dun seems to find a way to set WhatsApp message and photos to save in the microSD card.. anyone knows how and could share? Thank you very much
pat7471
You can move the existing media folder to SD card, but you can't change the default. In other words, new media will still be saved to internal memory. Here's more info.
Pocoyoz
how to get this 28 dollar off and dbs 10 off? use dbs debit card can get 10 dollar off?
No more liao.
Wait for 7 Jan electronic sale.
Dbs $10 off on Thursday nia.
Mon is dash $5 off.
barnabaskoh
hi,
can anyone say if getting 295 from unicell but 1 month warranty worth it? or is it better to get from mobilesquare for 325?
