Redmi Note 8
chesterqw
i bought the 231...then later got 1 more promotion...so bought another 1....:s13:
any smart watch to recommend that work perfectly for national steps challenge?
i bought samsung active but cannot use. :s13:
Can mah, sync watch to Samsung app, then in the steps challenge app sync to Samsung app
hellscream
Did anyone buy from taobao directly? It seems to be cheaper there.
I know it will be china rom, but I assume I can install g apps myself?
Thanks
valuesniper
Will like get some feedback : Is the earpiece speaker clear and loud enough? Especially if you are answering phone call in a noisy environment eg Coffeeshop, can you hear the other party clearly? I’m not referring to the speaker in the bottom of the phone, for blasting music. I’m asking about the one in the TOP portion of the phone. Thanks thanks.
hydeyoshi
Which seller is recommended at shopee or lazada to buy the note8 pro? Looking to replace my A1.. preferably with 1 yr local warranty.. thanks!
Sent from Xiaomi MI A1 using GAGT
wongminmin
Thanks
buy direct...+shipping fees more expensive.... then if phone damaged during transit.....
buy from local importer+coupon is cheaper, global rom somemore...then with 1 month warranty.
shopee is cheaper...... -$22 (ELDEC2) + bank for today
eventsapex (local) <-
univercell (export)
global tech (local/export)
mobilehubsg (export)
NightRaven49
univercell (export)
not really I feel. if u get from taobao, u can get 6/128 for ¥1399, which is under $280, and if u ship by forwarder like ezbuy, shipping can be up to $10 if by sensitive air (sea + gst not worth). so total is slightly cheaper than shopee, but not as worth since u get local warranty with the latter if u use coupon. but ur claim about damaged items during transit I've never encountered before, shipped 2 phones without issue this year, plus a whole lot of other items like tempered glass also nothing break.
hydeyoshi
univercell (export)
Okay thanks.
I read that miui has those ads is it? I coming from an Android one so dunno much abt miui thou I use a redmi note 3 before..
TheSnail
Okay thanks.
This is true on China ROM but Global one, not.
Last week we bought Note8 in HK for HKD1400 (SGD244) on Global ROM and seems to work well. Few weeks ago also bought a Redmi8 off AliExpress for SGD169(4/64gb) and also works well on Global ROM with nothing in the way of ads.
I had a Redmi 3S on China ROM a couple years back and had a lot of stuff coming up but my Mix2S on Global ROM has no ads.
Plastick
anyone facing this issue or got solution to it? tried looking into alot of settings and also comparing to my k20 pro but to no avail.
when the screen is off, any incoming whatsapp call won't wake the screen up.
when the screen is on, any incoming whatsapp call notification is not in full screen.
akarui hikari
For me, I didn't flash rom.
hello just want to ask your china rom rmn8 can voice search both eng (chrome) & chinese (native) browser? mine still china rom i install google myself thru xm app store but cant voice search eng, can show screen what google app u installed? which telco sim u got allow sg phone call? TIA
Audiology93
$230 for note 8t can buy on lazada can buy?
Nope. Redmi note 8 Pro 128GB only cost abt $240 after coupon+coins on shopee during sale... Maybe u can try waiting and see if there are any coupons by shopee.
Sent from Samsung SM-N950F using GAGT
alex22
Google lens can be used on ur rmn8 cn rom unit?
