Redmi Note 8
GoodBetterBest
I've made this mistake of pasting the tempered glass too near the front camera. Now there is a glare.
All my previous tempered glass has a cut out for front camera, this new one don't have. So didn't realise.
FYI.
Don't know if I can remove and repaste.
Zinc-Oxide
Can re-apply it, slowly take out and adjust
FYI.
Pocoyoz
which tempered glass to buy?
0.26mm/0.33mm/full cover :s11:
buy from TAOZI, ok?
GoodBetterBest
Can wash with water ? How ? I tried to reposition it when on by pushing but some dirt got trapped.
buy from TAOZI, ok?
Nillkin 0.26mm. They say not full cover but it's just a rectangular glass but smaller than the screen.
So as I've said, last time, my TP got cut out for camera. This is full piece and I didn't realise it cuts into the camera. I saw initially, I thought just the side, so no problem. But not, I confirm glare at the sides.
Zinc-Oxide
No, use tape to remove the dust trapped inside the screen or tempered glass. Do not use water ya!
When you lift up, use the tape you prepared, apply the sticky part on the dust and it will be removed. Before you do, try to go to your room, off your fan and make sure there is no moving air around
GoodBetterBest
If washed will still stick or what ? What about fingerprint ? Can wash off ? Or use sticky tape ?
carboy00
Pocoyoz
Nillkin have 0.26? only saw 0.2mm
will the film affect the front camera?
TP with black border better?:s11:
Pocoyoz
Could be 0.2..
The TP is smaller and if you apply equidistance from all side, it will cut the camera.
So beware.
I don't like with border.
Did you purchase from shopee/Lazada nillkin official? Seem like no local store selling.
The phone shipped out already, dunno can get the tp before the phone.
Sent from Amazon using GAGT
erwinrommel
I just got one unit of Redmi Note Pro 8 green 6/64GB for $269 in Shopee.
Considered expensive?
Planning to buy one for backup and for fun even though I have been using iPhone for years. I have quite ok experience with Mi Pad 4 Plus so want to try this.
lycanboy
I got 6/128 white for 277. now on the way to sg
