Redmi Note 8
davidwong
Actually why will you want to off your wifi when your phone sleep? Do you want the notifications not to come in ? Then use DND.
If battery concern then no need to concern cos wifi doesn’t eat a lot of battery
Or is it security concern?
Wi-Fi Off when Phone sleep :look:
Sent from Amazon using GAGT
Pocoyoz
Last time Wi-Fi has this setting option. Now don't have?
Switch from sony, which has stamina mode - off data when screen off.
Kennedy
it's android google problem. version 8 and above no more wi-fi sleep.
cscs3
Yes, WiFi is one element takes up lots of power. Especially signal is weak. Also, many program functions is set to operate only when WiFi is connected eg backup, sync data. These also take power.
Pocoyoz
cell standby (22%) use 5 times power that of wifi (5%) for 8 hours duration.:s22: mobile data is off.
dont know normal anot:s11:
maybe because starhub Signal strength 1-3 bars only.
virtualape
just got myself the Note 8 64gb version. value for money phone.
went to jb to look for tempered glass and covers at KSL. none of the stalls have it. had to order from shopee.
davidwong
Hmmm anywhere that can get note 8T with nfc and global set in local store, as I assume Singapore XM don’t have 8T right?
Audiology93
Finally received my Note 8 Pro from Shopee. Tried to check the delivery address to see if it's to Singapore but seems like they changed it to only state "Official International Version"?
Sent from Samsung SM-N950F using GAGT
qwerty8988
does redmi note 8 have touch screen delay issues at the edges when using keyboard etc? saw many ppl having issues on reddit and xda
erwinrommel
I just updated to MIUI 11.0.6 global, but it is still running android 9.
Any news whether it will be updated to android 10?
micgoh
How much was it ?
carboy00
Speculation that it's coming mid-March alongside Widevine L1 certification fix.
Posted from PCWX using Mi A2 Lake Blue
