Redmi Note 8
Audiology93
u got use my link?
got 2 links....1 shown international...1 shown country....
OHH saw it. My bad. Now it shows Singapore :D
Sent from Samsung SM-N950F using GAGT
Pocoyoz
what is your preferred network setting ?(*#*#4636#*#*)
mine is LTE/ UMTS auto (PRL)
on airplane mode overnight, battery % remains the same
but miui now cannot schedule airplane mode:s11:
carboy00
:s11:
Overnight battery drain with data off but network still on is very bad. Can't imagine with data or WiFi on. :s22:
Posted from PCWX using Mi A2 Lake Blue
Pocoyoz
No drain, about 3% with network and WIFI on. But moi want to use Dual sim. :look:
Sent from Amazon using GAGT
Audiology93
Mind telling me how you set up to tap for bus/mrt rides?
Add your card to Google pay. Then add you card into TL SimplyGo. After that just switch on NFC tap your phone at the fare reader with your screen on. Usually I will open the Google Pay app when I tap.
carboy00
Yup as answered by fellow member here. No need to launch GPay app to tap, ensure phone is unlocked with screen on and you will be able to tap for MRT and bus rides.
Posted from PCWX using Redmi Note 8 Pro Ocean Blue
GoodBetterBest
But has to be the default card ?
cutebeng
Hi all, why u all say the pro one is better? thought the Helio chipset has a bad reputation for performance? also, the local redmi note 8 has NFC?
carboy00
The Helio G90T chip in the Note 8 Pro model is a huge leap forward compared to past Mediatek processors. Plus only Note 8 Pro has NFC, standard Note 8 don't have. NFC is the reason I got the Pro version.
Posted from PCWX using POCOPHONE F1 Rosso Red
GoodBetterBest
To be honest, I don't know much about the CPU thingy. I just say that since I started to use, I don't have problem with the pro. The drawback for me is that the SIM/SDCard is hybrid. It's slightly bigger and thicker. The camera is in the middle and sometimes I touch it when I try to use the finger scanner.
The RN 8 does not have NFC. The 8T does have NFC but no local warranty.
cutebeng
icic. thank u for ur comments.
Severon
Ohh thanks
GoodBetterBest
Is it a must to add to SimplyGo for payment ? Somebody told me it's for tracking and claims purpose.
NightRaven49
no need, but good to have for those purposes. if they are not important to u then u can just straight away use bank card/set up on gpay, no need to create account.
Pocoyoz
Battery life not excellent. 3.5h sot in 3.5days use 54%.
