Redmi Note 8
confused
use this guide
1.you must unlock the bootloader
2.Download latest fastboot global rom
http://en.miui.com/a-234.html
MIUI rom flashing tool
http://en.miui.com/forum.php?mod=at...xNzhkMGQwOHwxNDkzMTg4MTc2fDgxOTExfDU4NDUxNg==
3.extract zip file by win rar apk
Win rar apk download
https://rar-for-android.en.uptodown.com/android/download
or extract by pc
4.Use the official miflash tool
.''Don't use SP flashtool''
flash global rom .
FLASH '''' clean all '''' option
Don't select '''clean all and lock''if you select your device will brick
do at your own risk
How to unlock bootlocker, read that its a frustrating process with a long waiting time.
confused
Good updates from those pioneers. NFC makes N8pro very interesting. What method did you used to load google services & playstore? Understand some do side load, some use china appstore to load, which is preferred?
I use the china appstore method, the app will install all the google playstore stuff.
confused
Nice. Self-load play store?
Nope use xiaomi app store google services app loader. After uninstall bloated china ware and turn some redundant features, works almost like a global rom phone. Already installed bank apps and NFC ezlink, nets flashpay, all works, but google pay app cannot open. :s13:
But UOB Mighty Pay works.
confused
Does anyone else have the redmi note 8 pro now?
Can you run install and run Androbench, run all benchmarks and share your Sequential Read results?
NightRaven49
waiting time not so long now. june i buy redmi note 7, wait 1 week (168 hours). recently buy mix 2s, wait 3 days only :)
Charlie_Zhan
just got the non pro note 8 today as a replacement for my spare phone.. and TPG SIM data, SMS and calls works well after setting apn and disabling carrier check..
matrix05
Thanks for going into the details.
gnixer
CN against global set actually is the same spec and physical phone except for the firmware?
alex22
Need to flash rom?
Audiology93
Sian cannot use Google pay :(
Sent from LG G7 ThinQ using GAGT
tanchinkoo
Does the dual sim both come with 4G (4G+4G)
thinking of buying one for my TPG also
Charlie_Zhan
if no one answer before mine arrive i reply you here
Yes it does..
Sent from Xiaomi REDMI NOTE 8 using GAGT
