Redmi Note 9
Broadwalk
I agree with what you just shared. I tried coating the SP with cheap ceramic coating from lazada.
Works quite well. Not sure how long the coat will last. So being an OCD, I usually change my Glass every 6 months. So i buy the cheapest generic i can find. . . ways of a cheapo . . . lol
Though I am cheapskate I have never tried apply SP myself. :o I will let the mobile shop to help me with that. :o I do thought of regularly replacing the SP but the amount of time and labor cost associated with the replacement deters me. :o
teoph04
Note 9s glass sp can be used for Note 9 pro right?
Posted from PCWX using SM-N975F
Backlash
Ok thanks!
Posted from PCWX using Nokia 7 plus
Word of advise when getting Tempered Glass.
Do go for the type with edge printing as they cover a bigger area and no white edges.
Tempered glass that are 100% clear are made smaller due to the formation of white edges. White Edges are non-sticking contact surface due to curve edge glass of phone screen and tempered glass adhesive.
teoph04
Oh ok, I already bought the Nillkin one with black borders... not sure if its the type thay you are referring to. But thanks for the advise.
Broadwalk
Can share the link? :o Like to see. :o
DenOOO
Bought the note 9 on shopee at $199.
Does it comes with pre-applied screen protector or back case ?
Backlash
Yup. That is the type. Tempered Glass with Silk Screen Edge Printing.
davidwong
Yes but the also depends on how Long you want to keep the phone nfc and also may have longer software support for the pro
But if you just want the cheapest all rounder with nfc decent battery life and performance and decent to ok camera and only want to use it got upto 2 years then note 8 pro
Only if you really need NFC. Differences are minimal, better primary lens (64MP vs 48MP), faster charging (30W vs 18W). Otherwise, more or less the same phone.
carboy00
I highly doubt Pro will have longer software support, Redmi devices generally don't have good software track record, my guess is Note 9S and Note 9 Pro will be on par when it comes to updates. I am getting more frequent OTA updates on my POCOPHONE F1 than on my Redmi Note 8 Pro in recent months, the Android 10 update for Note 8 Pro technically hasn't even left beta stage yet.
Posted from PCWX using POCOPHONE F1 Rosso Red
Devilsire
I just realised, RM note 9 series are specially catered just for global market & not china market. For china market, they're gonna release Redmi 10x series (with the same exterior look, not sure if it's note size) with MTK820 chip, which is reported to be better than SD845
So the 720g on note9 is like a dumping ground zzz
Sent from Xiaomi POCOPHONE F1 using GAGT
wongminmin
Is it worth getting Redmi Note 9 Pro over 9S?
see your needs and
price differences Vs specs differences
for me....
if 9s is $260, 9 pro is $319......i felt 9pro more worth.
now the only worries is note 10 release....will it affect note 9 series pricing anot....
