your lemon set ah?
still never occur any issue on my 9pro.![]()
I have no problem too.
Happily tap everywhere and my teban downstairs RC office.
your lemon set ah?
is it a no brainer to go for a Note 9S over a Note 9 as it is slightly better? And since the price difference is quite minimal?
Your already answered your own question
kana 9pro wifi bug again
left idle and wifi connected but no access
messages all no come in
damn unreliable this wifi
sigh
abit regeret change from mi max 2 to this
orginally wanted to buy another set for parent but nao deciede to wait and see if they fix this in their updates first
Can recommend some tempered glass and case for note 9s ?![]()
Not much choices actually, I got both my case n glass from Nillkin in Lazada.
Sent from Xiaomi REDMI NOTE 9 PRO using GAGT
Hab link ~? Gotch similar stuff in shopee ?![]()
bought from shopee
camera protected by the higher bump
solid case jus like the Ringke ones
cheap & good
Sent from Xiaomi REDMI NOTE 8 PRO using GAGT
yes, jus like the ringke caseThe back is plastic ?
I looking at the nillkin frost back case
~10-20% to 90%+ is definitely within an hour with 33w turbo chargingConsidering between 9s and 9 pro. Don't need nfc.
Hows the difference in terms of the 48mp vs 64mp camera?
Does the 9 pro 33W really charge alot faster?
Saw some reviews online saying 9 pro still takes about 1.5-2hrs to fully charge from 0-100, which is almost same as 9s.
