Redmi Note 9
Devilsire
compare with mi max 2 i find my new phone screen very small
if driving will be hard to see and use unlike the mi max 2
i tink is because the redmi screen is very narrow so when display maps looks small esp when u look at it from a distance when driving
tinking whether to relplace it and get something else
but got what other new phone with big big screen like the old max serie?
iPad lol
Sent from Xiaomi REDMI NOTE 9 PRO using GAGT
Broadwalk
I remember I saw someone mentioned delete the Ram Jet. :o I noticed the Ram Jet apps appear on my home screen. :o Any one experience that? :o
zzzzzzz
i realise something with the charger and cable (inside the connector is red) combo for 9pro:
9pro cable + 9pro charger = cannot charge mi max 2
9 pro cable + other charger = can charge mi max 2
other cable + 9pro charger = can charge mi max 2
9pro cable + 9pro charger = charge 9pro at turbo speed
other cable + 9 pro charger = charge 9pro at quick charge speed only
Broadwalk
full tank if going out
yes i kana before
deleted it and nao cannot get it back liao
it is some system app
You goto the security center or the cleaner apps, setting and see if the shortcut key is enabled or not. :o
I googled the Jet ram and google shows me the video to "remove" it from desktop. :o
Do you all run security center very often? :o
zzzzzzz
done that, its not in the list of shortcut apps
ZhuTou!
Turbo charge is like that de
Huawei also same
They have their own technology
ronnie
Do you all charge your phone to 100% or 80-90% only? :o
Most of the time I charge to 100, sometimes to less than that. However the thing I take note to do is not to let the phone charge at 100 for a long time. That is once it hits 100, I take it off charger.
My wife one, which is a Samsung S8 plus, 2 1/2 years liao, almost every night she charge her phone and leave it at 100 and no problem with the battery thus far.
Some more the Redmi Note 9 series, the battery last much longer than most phone, and couple with the fact that I rarely use the phone, can last me 2 days, which means I charge less often.
gregory_choo
don't have to worry about these. handphone has inbuilt hardware and firmware to take care of charging.
zzzzzzz
kana 9pro wifi bug again
left idle and wifi connected but no access
messages all no come in
damn unreliable this wifi
sigh
abit regeret change from mi max 2 to this
orginally wanted to buy another set for parent but nao deciede to wait and see if they fix this in their updates first
Devilsire
sigh
Personally never had issues with WiFi.
Am using mi router R3P with dual 2.4/5ghz both working seamlessly
zzzzzzz
maybe xiaomi connect xiaomi is ok
mine is asus my 9pro buay gam with it?
gregory_choo
sigh
9s better, no such problem :D
garychengjw
sigh
your lemon set ah?
still never occur any issue on my 9pro. :o
