Redmi Note 9
yusoffb01
Interesting that they enabled 4K on Note 8 and then chose not to with the Note 9 again.
Since redmi note 4 era, xiaomi have been hiding the 4k feature even when hardware is capable. Should be able to enable with rooting and editing xml file
eg note 5
Broadwalk
whats the current best price for redmi 9 pro 128gb now? for local set.
Shopee is still selling at 399. :o So the best discount will be 400 off 20 xiaomi shopee store voucher and 20 off voucher from electronic section, that will be total 20-40 off the 399 price. :o
cochran
hi
Anyone know how to change the "local backup" to be backup on the micro sd card for note 9s?
Thank you.
carboy00
hi
Thank you.
No setting to do it so the only way is after you have completed the backup you move the folder to SD card using File Explorer.
Posted from PCWX using Redmi Note 8 Pro Ocean Blue
Broadwalk
Is the issue with wifi cutoff resolved?
I been using WiFi and dual SIM M1 and TPG for my redmi note 9 pro and actively using it for my taxi business.:o
Running full load on grab apps, Waze, lalamove and zello apps, I do not experienced any issues.:o
Mine runs Miui 11.0.1 :o
Sent from Teban Corridor Airing Balls using GAGT
