Redmi Note 9
human_shieldz
Tried Astrophotography using gcam and only can capture clouds lol. I see some people can see like the whole milky way :s22:
hkchew03
:s22:
Sg not really suitable for astrophotography. Way too much light population unless you are in ubin or tekong.
It's possible but don't expect result to be superb.
Posted from PCWX using Mi Note 10
frozenoob
Anyone has any idea to remove the 'frequent' list in contacts? Same page as the 'favourites' contact. The frequent contacts suggested not even the people who I call the most. I tried searching online but like no solution
human_shieldz
I think it was XDA but i forgot the link, just google gcam for your phone. I think a month ago there was a non-root release for a version that works on almost every major phones out there.
teoph04
Ok thanks both, will try it out. Actually I find the stock camera quite good also.
Posted from PCWX using Redmi Note 9 Pro
human_shieldz
It's pretty good but the astrophotography mode is next level. While long exposure on the Pro mode in the Mi camera gives you bright photos, everything is brighten in the process but the gcam even things out and give you a nice bright photo without overexposure.
human_shieldz
That's not the link but i think it's newer though i'm not sure if there's a newer version since then. Think this one can try too
Veloso
Any recommendations for full coverage tempered glass SP for Note 9S? Got a few from Shopee but all came too small. Checked Monqiqi but don't think they carry this model.
bbcccc
https://shopee.sg/product/54054751/7633827608?smtt=0.0.9
https://shopee.sg/product/54054751/3620491841?smtt=0.0.9
try this
cheap and gd
Sent from Xiaomi REDMI NOTE 8 PRO using GAGT
Veloso
try this
cheap and gd
Thanks! :)
You are using this as well? Does the black border on the tempered glass SP 'eat' into the screen a little bit?
bbcccc
Thanks! :)
yes, it will eat abit into it but dun reali matter for me
Sent from Xiaomi MI NOTE 10 LITE using GAGT
human_shieldz
Bought from Aliexpress and it still leave the edge exposed a bit though the whole screen is covered and i think cos of the plastic case that came with it, it pushes the SP up so now the edge doesn't stick properly 😂 Shouldn't have done anything with it in the first place as the default SP was pretty good haha. Touchsensitivityy also drop around the edges too
OutBreak
The phone is not flat screen?
elf108
After update to June security patch, sometimes the unlock takes 4 to 5 seconds then response. Very irritating. Anyone face this issue.
i.c.e.d.c.u.p.p.a
My recently bought note 9 Pro is unable to detect the latest update and security patch. Anybody with the same issue? Miui global 11.0.1 and security patch is as of April
Sent from Xiaomi REDMI NOTE 9 PRO using GAGT
magixz
Note 9S is global version all got play store, global ROM. I dun need NFC, n I change once every 2 days overnight so 18w charging on my QC 3 chargers OK.
On miui 11.0.9, June 1 security patch.
Sent from Xiaomi REDMI NOTE 9S using GAGT
magixz
Bought from Aliexpress and it still leave the edge exposed a bit though the whole screen is covered and i think cos of the plastic case that came with it, it pushes the SP up so now the edge doesn't stick properly � Shouldn't have done anything with it in the first place as the default SP was pretty good haha. Touchsensitivityy also drop around the edges too
I wait till default screen protector ugly then I change tempered glass
