bbcccc
- Jun 7, 2011
was 379 before discount earlier on dewhy I checked ur link is 399-10-30=359?
but 359 still a gd buy
Sent from Xiaomi MI NOTE 10 LITE using GAGT
Missed the boat.was 379 before discount earlier on de
have been using note9pro for around 2wks and I found for apps using the fingerprint reader it frequently prompt that the prints are changed so need to enter password instead...
it is very strange since I've not add or remove any fingerprints since setup. not sure why but is quite irritating
Sent from Motorola Dynatac 8000X using GAGT
no leh...like DBS digibank app I setup to login using fingerprints alrdy but when i launch the app and tap Login the prompt to tell me my prints have changed and need to use password instead pops up....i didnt even have a chance to put my finger on the scanner yetTry cleaning the contact of fingerprint.![]()
Do you want to restart the phone or restored to factory setting again?
Most probably your settings messed up. Try remove fingerprints for both app and phone 1st. Then register phone fingerprint, before switching on fingerprint for apps. App will then prompt verify your fingerprint accessno leh...like DBS digibank app I setup to login using fingerprints alrdy but when i launch the app and tap Login the prompt to tell me my prints have changed and need to use password instead pops up....i didnt even have a chance to put my finger on the scanner yet
dun understandHi note 9 Pro users,
Is your video playback in HDR widewine L1 ? Or still in L3?
if u wan amoled can consider redmi 10x 5g .ard same pricehow is the lcd screen, mono speaker and the UI(Bloatware)?
still using nexus 6p, amoled + dual front speakers. but nowadays amoled phones price keep increasing sia
so other then the NFC and camera is it worth to get the PRO or the non pro version?
i manually disable the bloatware via Android sdk cmd. u can googled those that can safely disabledhow is the lcd screen, mono speaker and the UI(Bloatware)?
dun understand
tks! But too bad don't have dark grey liao.Flash Sale 379 now! but how u get $30 off and not $20![]()
Go electronic zone take 20 vouchertks! But too bad don't have dark grey liao.
$30 is from earlier post. I just checked is $20 only.
ohh...moi nv use Netflix so no ideahttps://www.xda-developers.com/xiao...-0-update-fixes-widevine-l1-hdr-related-bugs/
It is said when Note 9 Pro initial launch, it comes with only Widevine L3.......
then later software update provide upgrade to Widevine L1
So, i wanna ask, does Singapore variant has Widevine L1 in Note 9 Pro now ?
