Everybody and his dog benches 5 plates per side, squats a truck and deadlifts a mountain "back in the day".
The difference is that with the tempo he suggested, you're getting a lot more tension in the eccentric portion, which would cause a lot more DOMS.
It is quite evident that he is a rank beginner so why confuse him with the TUT talk in the first place?
Really curious on your take on the parts in bold. Thanks.
Gala, but would increasing the volume not achieve the same thing hypothetically speaking.
For example if the load etc. was kept constant. Would the effect of a 10 rep set with 4 sec eccentrics lasting say a minute equate to a 2 10 rep sets with 2 secs eccentric lasting for a min as well?
There are probably differences, but I haven't read the literature on it nor experimented enough to know. Personally I don't control tempo strictly, I have a controlled eccentric (probably ~1s), no pause, and concentric is as fast as possible.
@bear943 Based on what i know ppl normally count TUT as only the eccentric part of the movement. I.e. ur 10 rep set with 4 sec eccentric is going to be equivalent to 40sec tut while the other is 20sec. So the former is defintely going to be more effective.
