Replacement computer recommendation
kumpongboy23
Recommendation needed
Desktop just died.
I am old person non gamer.
Looking for a new desktop compueter. Budget around 1K. No need monitor.
Need also help to transfer file to new PC.
Should i get a USB data transfer cable or use window one? can already?
BlackWing1977
You can consider getting this with your tight budget.
https://www.bestdenki.com.sg/2916377-lenovo-desktop-ic-3-90sm002qst.html
Ask the shop how much it will cost to upgrade to 16GB, 16GB RAM shouldn't cost
more than $100.
Cannot believe my eyes... :oops: got people sell desktop with just 4GB RAM... really follow minimum required for Windows 11... and best part.. still costs $806... :eek:
Beelink GTR5 Mini PC Wi11 Pro, AMD Ryzen 9 5900HX (up to 4.6GHz), Mini Gaming Computer 32GB DDR4 500GB NVMe SSD, Mini Desktop Computer 4K@60Hz Three Screen Display WiFi 6E BT5.0​
https://www.amazon.sg/dp/B0B45ZQ8M3...d&sr=1-2-ac08f2b1-eb5b-4f1a-aa64-9e8f448c33ed
Saw this on Amazon SG... stocks should be local fulfilled by Amazon but might not have warranty (This one got to check)... but now got promo only $749... and pre-installed with Win 11 Pro.. there are review on YouTube...
BlackWing1977
Desktop just died.
You can buy pre-built.. or even one of the mini PC around since you dun game.. then get an extra external HDD to transfer file lor.. but since you said desktop died.. you might have to get some sort of enclosure to access the files in your old desktop.. but you need to check if it is 2.5" or 3.5" before you buy the enclosure.
froztheart
Desktop just died.
What's your use case?
86technie
Might as well go Sim Lim Square check the price, such PC best buy locally with warranty.
SLS does also have NUC like this for sale.
kumpongboy23
thanks
i am a noob on tech matter.
The old PC was a lenovo. Not sure if it is 2.5 or 3.5 inch.
Manly use to surf (edmw included} o_O
I like to open many browser and
speed is important as need to do some internet booking.
Where is like a few thousand people rushing for 3 slots available.
So what is moreimportant for me?
Memory, CPU speed or graphics card?
tq
BlackWing1977
thanks
tq
If you mean browser with many tabs.. I think it is more of a memory thing.. but I think most PC with at least 16GB should be fine.. unless on top of browser you still need to use other software that would take up substantial amount of memory.. then maybe need to consider 32GB... :sick:
ragnarok95
Senior Moderator
Senior Moderator
ryzen 5 5600 + asrock b550m pro4 $349(Dynacore)
Corsair LPX 16GB DDR4 3600 $75(Amazon)
Kingston NV2 1TB M.2 $78(Amazon)
cooler master mwe 550 v2 $68(PCtheme)
XFX Speedster RX6600 $362(Amazon)
Tecware nexus m2 air $45(Dynacore)
ID cooling SE 214XT heatsink $29(Shopee)
S$1009
froztheart
The old PC is lenovo about 8 yrs old.
thanks
tq
Was actually referring to this, use case as in what intended purpose/usage.
Agree w BlackWing1977, memory is your paramount concern, the rest can just make do.
BlackWing1977
Was actually to this, use case as in what intended purpose/usage.
As test I made sure I got 80 tabs are loaded... as I use ccleaner to do a sweep each morning, it is using about 5.6GB... so if you are like me sometimes game with the browser in the background can experience some sort of lagging sometimes.. especially if you are on 16GB... but most of the time is okay... I mean typical usage is a browser, maybe whatsapp, discord, steam software.. one to two file explorer windows open that to me is around 87% of my memory taken up and that is before I play any game.
