Replacement for GTX1650
naked123
durability depends on how you take care of it bah
either that or heng sway one
i suggest getting 2nd hand gpu @ carousell bah
86technie
Maybe I should just buy a new pc. Cost of repairing and changing parts could be high.
Is it true that DIY PC doesn't last as long as those big brand ones?
Depend how you use it as well as what type of components you pick.
Especially motherboard for DIY try not to go for entry/cheap motherboard.
neobear224
My DIY i7 4790k still going strong since Dec 2014. Almost 9 years of usage. Only 2 things that has spoilt on me is GPU and PSU. Swap them for replacement, everything in working order. I use a MSI Z97 Gaming 5 mobo,
idrinkecoke
Thanks everyone for the help, sent my cpu for diagnosis. No hope, MB is spoilt. So i thought i should just buy a new PC with warranty. Old parts from old pc will be removed as backup incase my new pc spoil in a few years time, old parts can be used to do testing.
naked123
how will the old parts be able to do testing for your new pc
should be not compatible unless you getting older parts
86technie
Motherboard spoil? Which shop is it?
FYI if motherboard spoil you can't even turn on.
FYI for Lenovo desktop, no parts except the RAM and storage can go over.
Other parts like power supply, graphic card can be reused.
However given the price rather just get a new Acer nitro desktop.
You can look for this one:
https://www.bestdenki.com.sg/2915899-acer-desktop-n50-640-i712r8512g36.html
