[Review] Dlink DCS-5222L (HD Cloud Camera)
koroshiya8
Hi all just bought this today from challenger. I have issue finding this cam on the dlink wizard. I have already connected via wps on both router and cam. But the wizard die die cannot detect. I have already disabled antivirus and firewall. Any advise where mght have gone wrong ? Before wps I tried wires also got stable green light but wizard just can't find the camera. TIA.
jcs_sgd
you can try using mydlink lite mobile app to add the camera if the wizard on pc doesn't work. I first used wired connect to it. on mydlink lite app, look for it under local device. I removed wired after I done wireless setup.
jcs_sgd
For a 32GB micro SD, how many hours can we record?
Thank You
it depends on your environment, motion a lot? do 24hr recording or motion trigger? frame rate and resolution?
for my case at home, I put motion detect, 640 resolution, 15fps, can last me 3-4 days. if you prefer 720p or higher frame rate, the file size would be very large.
I tested a few combination and got the video quality I am ok with.
koroshiya8
Thanks.. somehow it worked out.
My win10 die die cannot detect the cam, even though it is clearly in my network with an IP address... i access them via my synology first and later found that the device appears on dlink lite.
bear1sg
Wah, just saw at Challenger Funan... for some reason this model price drop to $169 leh!!! Usual is $200++. Even through still $10 more ex than show price...
@evq - u think worth the purchase?
sure or not? they drop price.. I just get one for family during last show @ S$ 159
bear1sg
any have problem using IOS to view on mydlink?
do no way can see any video this few day.
edwardkr
A1: 45.7° / 29.5° / 52.9°
B1: 57° / 34° / 66°
B2: 98° / 52° / 115°
B1 onwards have built-in speaker.
mine is latest B2, bought @ comex :s22:
been looking at their PTZ model since I bought their 942L bcoz the setup and viewing is really simple.
How to verify whether the model is B2 or B1 or others? I'm keen to buy.
surf2001
Anyone using this cam with ip cam viewer pro ? Like to know whether the 2 way comms work well.
Project_Xco
Hi,
Those who owns the DCS 5222L will surely notice this problem with their motion detection. Camera seems to detect it as a motion when the surrounding light flicks on or off. Secondly, when the camera switch to IR & ICR mode, the camera also detects this as motion. I search intensively on many forums including those from US and it does not seem to give me suggestions that work until i figure it out myself.
Firstly, do understand that there are two types of motion detection in the Dcs5222l described below.
"PIR" - detects changes in heat signature
"video motion" - detects pixel changes.
So, if you place the camera outside the corridor where it is lighted at night and receive good daylight, you can consider disabling the IR and ICR so when the camera switches to IR & ICR mode, it wont detect as motion. IR and ICR is required for poor or no lighting condition. This is the main culprit of false motion detection.
You can also disable video motion and use solely PIR instead so it detects changes in heat and not changes in pixels. This solves my problem when the light at the corridor flickers and it will not detect as motion.
Now the only problem left is when my wife cooks heavily and she don't close the main door, heat will escape and my camera detects it as motion. :D
AshSim
Hi,
They now have the 180-degree IP camera with full HD and HD720p... anyone happens to have them? I check their US website, looks quite good.... the specs not bad...
AshSim
Oh, I using qnap, don't have a synology Nas to test for u leh. U can check with synology website on compatibility models.
Dlink is well known, shld be OK.
I just got their HD180-Degree camera from IT Show... :D
