[Review] Netgear Nighthawk X8 AC5300 Smart Wi-Fi Router (Cnet called it : Router for the RICH )
trichard
This comment is good from a forum.
"Netgears new antenna design is very smart, and putting the other 2 radios on the inside is perfectly fine with me, its not like you need a second 5GHz with the same range as the 1st, and its not like internal 2.4 isnt gonna outdo external 5GHz, so 2.4GHz might be hit, but i dont wanna use 2.4GHz anyway"
Making sense that just design the unit as a router ... And a good coveage .. Instead of all antenna sticking out ....and quickly push out .. The design of the unit show how much consideration are done.
trichard
Coming soon - next week I will try out the port aggregation on NAS and will post result. I am also working on how to enable readyshare when my unit is a AP .
Apparatus
Trichard
Check something.
1) Is the MU-MIMO enabled?
2) How's the Smart Connect working? Got 2-band & 3-band selection?
Thanks
trichard
Trichard
Check something.
Thanks
(1) - end of the year firmware will be ready.
(2) - SC thru 5G BAND without 2.4G. Working well as only 2x 5G.
What happen ? Some issue with your AC5300 ?
Apparatus
Re
So the SC only works on 2 bands (5GHz-1 and 5GHz-2). ASUS AC5300 can have 3 bands SC i.e. inclusive of 2.4GHz as well
Issue? Yah lah. 3-band SC will put almost all my 5GHz devices into 2.4GHz band. 2-band SC still reasonable. Puts some of my 5GHz devices in the 5GHz band and some in the 2.4GHz band
xonix
That's until you accidentally break it... :p
trichard
Last day ......... before it goes back to 699..
trichard
Your X5300 can also I think .... SC 5hz and leaving 2.4G out ....
saj282
Yeah, $599 at Sitex, comes with a free AC1200 WiFi USB dongle.
Hope it really does provide a wider coverage.. this is my 5th router since moving to my current apt.
trichard
Waiting for your post about coverage... What is the other few routers??
