Rig is running HOT when IDLE!!!
ducky_88
I just brought a rig, and the best part is this pc is running at 38-40 degrees at idle. While playing flight simulator x it can runs up to 72 degrees. I had done OC to 4ghz. Vcore is set to auto.
My question is how can I bring down my idle & max voltage and at the same time. I also did reapply the thermal paste but it is still running the same temperature.
My rig details:
CPU & MB: Intel i5-3570k with Gigabyte Z77x-UD3h BIOS: 19e
GPU: Evga 560Ti SuperOC
Casing: Fractal R4
CPU cooler: Corsair H80i
Any details i left out?
ducky_88
I can't play my game in peace. Worry I might burn my chip & GPU. I also intend to OC to 4.2 or 4.5Ghz if possible. :(
eminus
dont worry Intel and it seems you have a good mobo they will throttle down your processor if it reaches 100c.. you will know if you hit 100c if you suddenly have lagging and such.
Ark Law
Dun be lame la, that temp is normal and can be considered good esp after OC some more
ducky_88
Glad to hear that. Thank you. Will have a piece of mind to OC higher.
This is my first expensive PC. :( Don't really play hardcore games only FSX.:s13:
eminus
ducky_88
Consider using manually set Adaptive or Offset Vcore instead.
Not really good in Vcore thingy. Care to share what Vcore should i set it to? I did try afew x but system not stable, thus i put auto.
that is normal temp rah
Noted.:D
if you really are concerned about the temp of you chip then I would suggest you have you chip delidded. you have two choices if you are in east area you can contact this forumer
Delidded 4770K on a Naked run!!!
if you stay in the west area you can go to ministry of PC
https://www.facebook.com/MinistryofPC
Got no idea what is delidded. But will read up on the link provided.:D
spyboy48
manual set vcore to 1.15volt and try 4GHz it should boot....next try 4.1GHz.
and so forth....Good luck and enjoy :)
Average 4.2Ghz needs at least around 1.15volts, 4.5Ghz might be tough as most 3570K needs around 1.25 to 1.3Volts. And that contributes to heat as well. So ideally 4.2Ghz would be sweet and nice.
Loadline Calibration sets to "Turbo", and that allows a bit of vdroop and can protect your chip from dangerous voltage spikes when overclocking.
Do not set to "extreme" unless you know what you're doing.
Stress test with Linx to confirm stability.
foo9883
Go and delid your ivy-bridge haha.
Will void warranty though. Depends on whether you willing to take the risk or not.
ducky_88
Just OC it to 4.2 at 1.17volt. However this time round the temperature for all core runs at 30-38 degrees at idle.
Ark Law
That's good, the most I can get at idle at stock 3570K clocks with power saving mode on is 35degs (Antec 920, noctua nf-f12 pull, silent fan profile)
prezioso
my 4 years rig. idle temp is 60 deg:s22: play games at 80 deg. also never spoil.
anyway car engine temp is 200 deg and more. i dont see the car metal melt. :s8:
