purpleberry
- Nov 23, 2008
Corsair Obsidian 250D can fit R9 290?
Why you don't think excel is very well threaded?
Companies have long shifted to quad cores (i5) as the standard with power users given i7s.
Excel files used in business today is not the simple 65,000 rows with simple sum function.. I'm talking about 300mb single excel files that are literally statistical juggernauts combing through data to find patterns with multiple formulas that are 4 lines long
That is just raw data not to mention pivots that consolidate the results..
don't think excel is so simple, can? ;p
Btw, your one to talk... look at your own rig... titan black with a single 1080p 60hz.. lulwut? Do you get fps higher than 60?
Also what are you using your 4770k for... just purely games? Not even video editing?
I cant imagine microsoft excel requiring more than a i5 4440...but oh well
4K tv coming soon (;
I dont want a 1440p since its not a formally "established" resolution unlike 4k or fhd so id rather wait for a 4k monitor of the same size![]()
If gtx 880 comes ill get it too cheers
4770k is just cause i want to get the best haswell since i have the best gpu i dont want anything to bottleneck (;
I'll tell you what... On those very same excel files that I mentioned it takes my current 2600k 8 core (4 physical) running at 4.6ghz each 5 minutes every time I ask it to re compute all the data... I get out of memory errors after the 2nd refresh run because I'm just using the 32bit excel 2010 version... I will upgrade to latest 64 bit version but I'm just making do so far...
What are you talking about 1440p is the standard now with 1080p going the way of the crt display... almost all the current benches are in 1440p...
by the time your 4k monitor becomes cheap enough your titan black will be long outdated... The original 4k screens came out with a $3k price tag and a 30hz refresh rate. ..
There is no way in hell that you need a titans 6gb Vram... You would have been equally served with a normal 780 with a rinky dink little 1080p with a bad ppi at 27 inches.... so scared of bottleneck that you got a 4770k when a 4670k can do pcie 3.0 anyway...
I'm running 780ti sli on my 2600k with no perceivable bottleneck even at 5760 X 1080 even when maxing the Vram on games that support txaa...
so let me give the same advice... If no regrets for you buying that rig then happy lah... lulz...
:O. 5 mins on 2600k?
What kind of monster excel files you do LOL
Im very happy ps and i intend to upgrade to 880 or higher when it comes out![]()
Cheers
What are you talking about... 1440p is the standard now with 1080p going the way of the crt display... almost all the current benches are in 1440p...
Protip - your monitor is now your bottleneck... lulz...
all this may be true but I don't think anyone will like hearing (or reading) these things after spending (what may be to them) a bomb on their rig parts![]()
Well..it does give him options to get 2 more monitor or upgrade to a 27" 1440p if he feel he needed to
Sometimes ppl hoot stuff within their budget, they happy can liao
They use the rig..not us
I'm envy to see ppl use such rig, if I got $ I will maybe get similar stuff just for the songness![]()
So you admit that your rig is not the best performance to dollar wise and yet you come on other threads with the same concern... lulz... Cheers to you too...
nah my rig isnt meant for performance to dollar mine is meant for pure epeenz plus smashing ripping power should i require it
actually idk why you brought my rig in to compare seeing that mine has very different purposes and its not meant to be value-oriented but rather what i can afford comfortably. I like playing with benchmarks with mine although not the extreme LN2 sort but maybe just OC and see 3Dmark Firestrike hit 11-12k for fun
as for yours im not sure if value was a key concern but im just sharing that perhaps for most requirements an easier processor could've probably done the job and saved you money which you could've channeled into the gpu
cheers
Erm, is the titan black released in SG? If not, how he got it? Just realised that...
rest of my rig from pct thoughOpps, its not titan Z... I tot he got that..
