Robot Vacuum Cleaner
firesong
Deluxe Member
Apart from Dreame and Roborock, don’t buy other brands. You will definitely regret it. Haha
Ah, this is a bit sweeping.
Care to explain why? We were planning to get the Xiaomi X20 Pro due to our tight budget. Half the price of the Dreame/Roborock.
elvintay07
Suspended
I think at 1/2 price ok la. I tested Ecovacs, Dreame, Roborock and Xiaomi. I think both Dreame and Roborock are good. Ecovacs sucks for the quality. Xiaomi I think ok but I don’t think the performance is as good. Can go China website to see
MrTheROCK
I have roborock and xiaomi
roborock very good :o
xiaomi really value for money :o
hkchew03
Mova (sub of Dreame) seems to have some interesting options at budget.
Uwant might be another one to look out for with roller style mop, their handheld vacuum is quite highly praised.
elvintay07
Suspended
Uwant handheld vacuum like very impressive
DriftKing
Any recommendation for wet/dry handheld vacuum?
So far contenders are:
Dreame H15 Pro
Roborock F25 Ace
Narwal S20 Pro
All these I like coz water tank is at the bottom, Narwal the best hidden behind, read people crack their water tank for Roborock when they hit something in the front. Dreame I personally using their normal vaccum ok, but read logivity issue with their wet/dry vacuum.
Narwal seems the best given its sleakness, though not as function loaded as the rest but I don't really need fancy app and stuff. Only got hard tile + wood parquet floor to clean. Wont have much food mess to clean so don't think need heated water.
But problem is Narwal doesnt seem to be well tested locally, not sure if warranty will be covered.
i_dun_understand
I got the Roborock F25 Ace and have been using it for 7mths. I choose this because of the zero hair tangle at the roller. Saw quite a few china review and Roborock seems to be the one with the zero or least hair tangle. Some even use 1 metre hair for extreme test case. Among all the brands, Roborock is also the lowest height when lay flat on the ground. Also the suction power don't get reduced when lay flat (for auto mode).
I didn't have the crack water tank issue. I guess others must have hit it very hard against the furniture when using it. My mum used it once and she comment that not heavy to hold. I used to have dreame H12 dual and that was quite heavy to use. Can train your arms muscle when using it.
Quite a few china review say Narwal easiest to manoeuvre and lightest to hold.
Below is a recent video of the china latest top tier model comparison. Only Tineco one is available in SG as of now
Atrina_Boy
My current roborock start to having issue like motor noise starts to get loud and vacuum performance lately even throughout clean and changed accessories. Would like to give a try on xiaomi. Anyone try this brand before. Appreciate your kind inputs. Thanks in advance
natas
I am using xiaomi x20 max.... till now no problem and best bought equipment, "happy wife, happy life" :D
