Robot Vacuum Cleaner
CyanCyan
In all honesty, if your home is new or fairly floor empty.
robot vaccumns will be your best friend. :o
But do take this in mind, good as they are, dun expect them to clean where there are things blocking. eg like under the table where you have chairs tugged in untill it cannot access.
Or you have high door ledges or stepped areas.
But I can say it will cover 100% of the entire area where accessible :o
sAVaGEmP5
Neato can chek win every model u guys mention. Waiting for v2 or v3 only. If its listed i would have bought this company shares. Next time i believe can update the floor plan into the machine so less time for AI learning.
Youtube "neato" or neato vs irobot.
but ppl just dun admit cos most ppl bought irobot liao.
I ordered frm US amazon last time ahh now sg also have distributor liao
herzberg
Moi ish using Neato. Does the job well, sucks dirt, dust and hair. Hair tends to get stuck at the beater brush but easy to clean. It's rather loud, compared to other robot cleaners but just close the room door and let it work and you'll barely hear it.
Unlike the rest of the robot cleaners, it moves in straight lines and not at random.
Takes about 3-4hr to charge up and can last about 1hr. There're some sites out there that teach chiu how to mod it so the suction can be stronger or to weaken the suction so batt can last longer.
The leceh thing ish need to clear things from the floor, e.g. bags, chairs before using, or it'll spend moar taim navigating the obstacles than actually sucking up dirt.
herzberg
Oh, a Neato owner. I did a fair bit of research before settling for Neato. I was sold when I saw the comparison vids and reviews.
Got mine from autovacstore.com for 699 last year but hardly use it now.
CyanCyan
Why not set timer daily? :s11:
mypillowtalks
I rmb my friends bought the neato robotics vacuum, dismantle it to make use of the laser thing to map something.
Before that we mess around and see how it works. Basically the vacuum hav many switches around it, when it runs into the wall the switch closes and the robot move in the opp direction.
I also rmb they duno do what accidentally then something that messes up the programming, the cleaner will not go back tothe charging station. Keep stop a distance away.
But this was at least 3-4 years ago
sAVaGEmP5
I still use it. But i was quite worried abt the filters and batteries, but last check neato got local distri, and accessories.
I do not know y ppl go for irobot. They shld see the u tube video and the algo how irobot moves vs this.
CyanCyan
Same as ppl dunno why you keep want to say Neato is good, :)
No offense, but that's how it is.
But hey, as long as they does the job who cares what brand to use
totopetz
Me using Neato.
Noisy but effective.
Much more intelligent than iRobot, as it maps the room with laser rather than impact sensing used on the iRobot
Shalomp
I know which video u talking about. Shows how much better Neato is at picking up dirt and finding its way around a room than roomba
But honestly u don't need to see it to believe it. Any smart and discerning shopper who read up a little before making the purchase will know that Neato is so much more systematic in going over a room layout. Roomba just moves in a random pattern bouncing off walls and the user has to pray and hope that it doesn't miss a spot in all its randomness
I think the only area that it loses out to roomba is the noise level. But that's secondary as my primary concern is effectiveness and cleanliness
Summerholiday
Not promoting. Just a piece of new information only.
A new robot call rulo from Panasonic launch mar 2015 in Japan.
Brief description: Triangle shape to get in corners, light indication for dirt level, infrared and ultrasound to detect obstacles and window glass surface, 2 movement random and surround, prevent drop from edges, spot mode available, climb mode 2mm, auto return to base for charging, remote control. Recharg cycle 1500x. Weight 3kg height 92mm. Cleaning time 60min, charging time 3hr. 33w.
derrickgoh
I would rather stick with LG. They've been selling vacuumbots for far longer and I rather go with an established product.
ralfale
Been using roboking 2 years. Still running healthy daily when I'm off to work. I can safely say all the bs about low suction power vs other bots are invalid. My floor feels clean daily and every time someone comes to my house a very frequent question I get is "you just mop?" It simply shows how effective roboking is even when I mop my floor once every 3 weeks!
wenwen91
How long do you have to charge it for most of the time??? Does it use a lot of electricity?
extboi
Well.. i have just bought 2 neatos from ebay at 350 sgd each including shipping
BlueteethW
Any one bought Aztech Smart Robotic Vacuum Cleaner VC3000?
Seems that it is cheaper on market.
