RTX 3000 AIB Cards
d3fc0n
would i need a 850w psu if im going for 3080 AIB cards like strix? or 750w will be fine like FE requirements?
icheb
I think 750 is still the bare minimum. However, the Strix needs 3 x 8pin connectors. So just make sure you have 3 dedicated connectors at the back of the PSU.
Van darkholme
Dynacore seem to be accepting preorders can go their FB page see , got ASUS, Gigabyte, Zotac , Msi on their latest price list but no price yet
koicafex
depends on how many fans and whether you're overclocking everything
cpu + ram + gpu
and how many ssd/hdd etc...
my 750w gonna barely make it cos i got sound card as well
d3fc0n
cpu + ram + gpu
think i play safe to buy a 850w. i bought a sound card as well. im still procuring parts left gfx psu and casing
d3fc0n
planning to get seasonic 850w i guess more than enuff
icheb
just go 1000w or 1200w for future proof sake la :s13:
Yeah thats what I did. Just went with 1000W. Gives you a greater peace of mind for future peripherals and what not that you might add to your build.
d3fc0n
cant find seasonic prime 1000w on lazada. wanna make use of 9.9 sale to buy
Hailgod
just know that when ur psu is too big, your idle power draw will be below its 20% power draw where your 80 + bronze silver gold platinium is measured.
at that kind of power usage, the efficiency of power supplies can be much worse than rated.
m0n0n0ke
Hope soon someone stsrt to make custom cables for 12pin to 2x 8pins
icheb
just contact Dynacore. Apparently, as of this writing, they only know that ASUS TUF is coming on Day 1. No word yet on Strix models.
Didn't enquire about the other brands.
ragnarok95
Senior Moderator
Senior Moderator
Even if you are using 10900K with 64GB with many SSD and HDD and sound cards and this and that with a 3080, a 750W is enough.
hafiz116
Most people go for the 650w so that would actually be the real question :s22:
Curious if my NZXY H1 ITX (650w) build will work with a 3080. I only have a 2TB NVMe installed and do not plan to add anymore hard disks. The CPU is the R9 3950X which could put me at risk of stability problems - will need to test I suppose!
kennerv
their spec already put required power is 750w.
Gametaku
In the past, when system requirement was 500w, ppl went for 650w 700w psu. But when system req is 750w these days.. Ppl is asking if 600w 650w psu will work. =0
UnFoly
Correct me if im wrong but only the FE models uses the 12 pin, all other AIB cards currently use the standard 8pins and you dont need the dongles for them.
