Ryzen 3600 Build Thoughts?
watzup_ken
got the above setup and was delivered 2 days ago.
everything is running well and temp is good, though considering change the fan arrangement by adding in some case fans just in case.
Enjoy man. I am not too sure how many stock fans came with the casing you got, but good to make sure that there is enough airflow.
RanDream
thanks man!
came with 2 stock 120mm, thinking to add 2 more 140mm at the front and shift the 120mm to the rear and top (nearer to the back).
SkyShroud
so cheap?
local price super inflated or what ermmmmmmmmmmmmmmmmm
where and how? i see amazon smelly smelly also 400 for 5600x
SkyShroud
R.E.A.D
Maybe you entered the wrong thread.
this is Ryzen 3600 thread
Still not reading? Need me quote for you ah?
Your ego too big, people tell you to read, you better guai guai read.
Wrong means wrong, if you can't deal with it, don't come forum okay.
was able to get a better bundle from another builder, preferred mobo and ssd oos though so have to go with other type.
looks good and most likely will go with it. good thing I asked around here first.
Processor: Ryzen 5 5600X
Mobo: Asus Tuf Gaming B550M-Plus Wifi
RAM: Klevv Bolt X 3200Mhz 16GB (8GBx2)
SSD: Samsung 970 Evo Plus 512GB
PSU: Superflower Leadex III 750W Gold
Case: Fractual Design Meshify C Casing
Total: $1,056
stylechap
Ok can you win
but based on your reaction i still think you need anger management course
