S3 Slow Charging
XDarklytez
Thanks to this thread finally got a place to ask my question. My s3 charges up from 18% to 84% in 90 mins. Is that ok? Then my s3 takes 4-4.5 hr of screen on time to drain 100%. Is that normal too? Sry I very paranoid after I knock my s3 against my home gate.
Nickttmseller
Just tell them Slow Charge.. the CSO will noe wat u mean...reason bcoz it's quite a common prob..by now all Samsung Service Centre staff will noe..hahahah...
as long stil under e 6mth warr, they do an 1-1 replacement to u..no qns asked
Ok Thanks.
mib1800
I find this makes a different. Plug in charger ONLY when the phone is on standby (i.e. when screen is OFF). If the screen just turned off, then wait about 30 seconds before plug-in. Charging time with this is about 2 to 2.5 hrs from ~10% to 100%.
If you plug-in with screen on/while using it takes up to 5 hrs.
SherSher86
I went to exchange the battery and charger. Then I told the staff about the phone heating up, she told me could be motherboard and advised me to replace the motherboard.
I told her i try with the battery first :/
Anyone has the same issue? And replaced the motherboard?
konoha
wow, i oso having this slow charging.. and sometime the batt heated up easily when i surf net etc.. so should i change the phone batt and charger?
fuschia
thanks for sharing. i shall give it a try. during charging, does it matter if we use the phone?
freedom-strike
i also encountered the same issue.
what i usually do is that if it is charging too slow, eg. after 5 mins, still do not increase by 1%, then i will plug out, adjust the adapter and the usb cable and then plug in again.
most of the time, it solves the problem.
however, i never encounter slow charging of my S3 when using my blackberry charger in office, so i suspect it's adapter/usb cable.
ya! tats wat i did too..unplug n plug in..it works bt nt all e time.. hahaha...
in e end i went svc centre just now..they told mi its a common prob n they exchange a charger n cable to mi.. now i use its working very fine.. n strangely e charging speed up.. 10mins 9%!!! Mayb you will like to visit them for ur issue as well. :)
To all S3 users having this problem, usually the problem lies with the charger+usb cable, or, the battery? If it's either one of those, do you all exchange just the charger/usb cable, or, together with the battery as well?
When I googled around for information, what I got from another site was:
"What do you mean by "really slow to charge"? A couple hours or a bit more is normal depending on how low you are. This is a 2100mah battery, so it's larger than most standard smartphone batteries. Also, you're not draining your battery down to zero are you? You should plug it in when it gets down around 20-25%. Draining it lower than that will take much longer to charge and its not good for the battery to drain it to zero. "
True or not? Getting the battery down to below 20% will only slow the charging?
Anyway, here's my input of what happened so far, from my observation -
9th February 2013:
Purchased and played around with the device till the battery was down to 4%.
At 1900hrs: Started to fully charge the battery using the original charger+cable (4 pins) that was provided, for the first time and realised that the charging was extremely slow. And it got to only 24% by 2100hrs.
10th February 2013:
At 0755hrs: Battery was fully charged to 100%.
At 1804hrs: While at work, the battery was down to 48% and I tried charging it using a Nokia charger (5 pins), the charging was fast as it got to 58% by 1825hrs.
At 2300hrs: Back at home, with the battery at 18%, re-charged using the original charger and realised that the charging was very slow again like how it used to be.
11th February 2013:
At 1100hrs: Battery wasn't fully charged and was only charged up to 81%.
At 1200hrs: Decided to change and tried using my HTC Sensation XE charger (5 pins) instead, charging was fast and had gone up to 95% by 1225hrs.
Some even mentioned that the charging issue could be due to the micro usb cable having 4 pins, which slows the charging.
"Another thing you may try for charging :-
The micro usb cable supplied is having four pins (there is space for 05 pins). Try using a cable with 05 pins. This may be a wild guess but i have 02 cables one with four pins (came original) - giving charging problems. another cable i have is having 05 pins and it charges great. I am not sure but worth a try.
during poor charging problem i faced earlier my phone would charge less than 20% in 01 hour. Now it charges at rate of approximately 1 % for every 1.2-1.4 minutes( approx. 40-45-50% in 01 hour)
except when it is almost charged to more than 95% when it takes almost 3 minutes or more to charge 1% "
Another solution to this problem is:
"Before updating to JB, I thought my phone would have the charging issues as well (which it did have after updating) so I searched for possible fixes for the slow charging issue. You might wanna try this one, as this worked for me:
1. Plug your phone into the charger (battery removed from the phone).
2. Wait for a few seconds (phone still plugged in without the battery) then insert the battery and quickly turn the phone on.
After doing this my phone charged faster compared to the 6-7hour charging time of other users. The first time I charged it after the JB update I already did this and it charged for 4 and a half hours to 100%. Right now I'm charging it for the second time -- after 3 hours and 20 mins. it's now 100% (from 40% charge left).
I hope this could help. Cheers!"
Enlighten me please.
Just Me
Before you confirm it's the charger's fault. Make sure you check the battery info page when charging. Sometimes, even if you use AC, it will report as USB charging. In this case, just off/on again the mains and confirm..
I kanna before on my S3 just recently after updating to wanam's latest firmwares. Also had this kind of crap on my nexus 7 as well.
freedom-strike
Check the battery page, as in, by going to Settings > Battery , at the top part where it says "94% discharging"? See whether that changes to USB or not when charging?
bluestone27
also have this prob with my newly bought s3, then i used my father's galaxy ace's charger to charge and the speed is around 8% every 10minutes. Anybody knows if the galaxy ace's charger is suitable for my s3? or will it damaged my phone
Just Me
Yeah.. dat's right ;)
But if it stays at AC, it won't suddenly jump to USB charging. If that happens, then your charger or cable is faulty
Mystech13
My bro s3 also had the same problem. But charge perfectly find with my note2 charger.
freedom-strike
Those having this problem, just go to the Samsung Service center at Plaza Singapura to get a replacement. I got mine changed and it's charging very fast now.
pinpinpin
Suspended
If my phone is 7 months old now and i would like to exchange the charger at CSO due to slow charging. do you think it is possible for 1 to 1 exchange?
Kindly advice.
Thank you.
Ev0d3vil
Hi guys, if slow charging just go down change charger? Need to bring anything? Will they check if phone rooted?
