Samsung Galaxy Note 10- Let's speculate...
Gaminator
Fp sensor still work boh? :s11:
Still works, and as I'd stated, better than the WSD one, which was a miss most of the time (I mean, sometimes require 2-5 tries to unlock). FP sensor on Note10+ still not as good as the one on my previous P30 Pro, I understand they use different methods. Most of the time, I need only press and hold for a second to unlock.....unlocks most of the time. With the WSD, it was a crapshoot, might unlock sometimes, but more often than not, must try more than once.
micshang
March Update available OTA for Malaysian set
One UI version 3.1
Ev0d3vil
Got a small dead pixel on top left of my screen.. any idea how did this happen? Didn't drop the phone at all.
Where can I go and change a cracked screen for my Note10+
How much will it cost ?
Will the service centre charge more than other shops ?
I usually go those third part ah beng shops in the heartland....quite cheap as compared to service centres. But you must be firm la dont let them overcharge you. Go a few shops to compare price first cos they should all offer similar rates one so you know you are not being cheated.
Tony.Manero
With adaptive battery, the phone last quite long. It goes into moderate performance mode automatically to use less battery.
tt32003
Think main issue is whether to change only the glass or whole LCD screen
One shop says Samsung screen quite thin so need to change whole thing
And that will cost close to 400
Think only reliable place is Samsung
Ah Beng shop may say only need to change glass then half way say need to change everything.
stupidog
i think go back samsung svc ctr better cos when u opt to change new screen,
they will change a new bezel and a new battery for you as well.
furthermore it only cost you $395
i just helped my sister replaced her cracked LCD.
ah beng shop change wans , u can forget about water-proofing and may get a 3rd party LCD :s22:
samsungXP
3.1 ?
Sent from Galaxy Note 10+ using GAGT
