3.1 is out for HK set
Are you having Volte problems sometimes on your HK set? Like it goes grey then only comes back when you restart your phone?
No such problems. Maybe has something to do with the telco you're with.Are you having Volte problems sometimes on your HK set? Like it goes grey then only comes back when you restart your phone?
Green![]()
VoLTE will be enabled only if you have 4G. So if your signal drops to 3G/2G definitely VoLTE would be disabled bro..
Wipe cache partitionAnyone can assist on how to clear cache?
- Turn off the device.
- Press and hold the Volume Up key and the Bixby / Power key.
- When the Android logo displays, release both keys.
- An 'Installing system update' message will show for 30 - 60 seconds before the Android system recovery menu options appear.
- Press the Volume down key several times to highlight wipe cache partition.
- Press Bixby / Power key to select.
- Press the Volume down key to highlight yes, them and press the Bixby / Power key to select.
- When the wipe cache partition is complete, Reboot system now is highlighted.
- Press the Bixby / Power key to restart the device.
Why 'unfortunately'? That's one of the reasons why I've given up on China branded phones like Huawei, no Play Store, die die must have one leh!Removed as much Google apps from my phone as possible.
Unfortunately must keep playstore
Google apps are too intrusive. But it's the best app store for Android. So I removed everything and kept only play store.Why 'unfortunately'? That's one of the reasons why I've given up on China branded phones like Huawei, no Play Store, die die must have one leh!
Got pic to show? Other than resetting phone, don't think any thing else help. Try setting lower resolutionThis morning noticed a vertical green line on the extreme left side of the screen, tried recalibrating the colours, reset etc. but to no avail. Looks like lcd up lorry, anyone experienced the same issue before and knows the cost to replace?
Battery seems to gets longer to get charged to 100% despite super fast charging
Samsung SIngapore charges $352 for Note 10, $391 for Note 10+This morning noticed a vertical green line on the extreme left side of the screen, tried recalibrating the colours, reset etc. but to no avail. Looks like lcd up lorry, anyone experienced the same issue before and knows the cost to replace?
