Samsung Galaxy note 2 tips & tricks plus issues.
kero89
just checking, how long ya guys take to charge your phone? mine take 8 hours to charge from 5% to full. using their supplied charger and cable, directly plugged to the wall. I'm only getting 35% efficiency.
satch
Mine takes 2 hours max....is yours the 2A original charger?
tohchr
Mine 2 hours from 0-100.. Just bought the external Samsung battery charger stand with additional battery.. Now I can charge using that..
slang
i m a new samsung user here converted from iphone...would like to knw how do i copy a word or sentence?
have been struggling for a while especially i m used to iphone double-tap and drag copying style
Lil_d3viLz
Hold it there.
monochrom13
Hi, iphone convert here. Did anyone notice the issue with wallpapers? Please don't tell me to get one with better resolution as I tried way higher resolution then the note2 screen. I can view the wallpaper fine but once I set it as wallpaper it seem to stretch. Am I doing something wrong or its a bug? The stock wallpapers seems fine.
monochrom13
I found it, guess its a known issue.
http://forum.xda-developers.com/showthread.php?t=1933827
sinsevil
My Screen on the left centre area are unsensitive, I need to press a few time to open the folder. Another bros got this problem??
intenn
Left side? U try to open sketchbook to draw something on the side which u think is insensitive and see does it have a problem.
