Samsung Galaxy note 2 tips & tricks plus issues.
zachxx
need help on haptic feedback too!how do i on the vibration if i wan it to vibrate when i press the menu or back button?tried on white note2 can but grey one cant.
samson1
HI all,
Need help and advise here,
my Note 2's TouchWiz unable to remove page.:s11: Whenever i drag the selected page to the recycle bin, it hang a while and pop up msg indicate TouchWiz closing.
Anyone encounter this before and pls advise what can i do to remove the unwanted page.
Thanks in advance.
You can try resetting it to default setup but you will clear everything on the home screens. Go to settings, application, all, touchwiz home and clear data.
samson1
Go to sound settings and turn on haptic feedback.
manaeater
hi guys, is there a way to remove the "Starhub" words on the notification centre near the bottom?
very irritating sia the works...or only rooted devices can do this?
Thanks.
kennyboy
Thanks.
It would be very bad if they actually didn't show the network u are connected to constantly. :D
BryanLim80
Hello Friends,
Need help and advise For my Note 2,
my Note 2's TouchWiz unable to remove page. Whenever i drag any selected page to recycle bin, it hangs for a while and pop up msg indicate TouchWiz closing.
Thanks in advance.
ltrinityl
Hi all
I am having some issues with my note 2 lock screen. The lock screen unlocks itself whenever I turn on the screen. Anyone with the same issue here?
Any solution to this?
Platform_A
Hi SNote2 community, I would just like to ask if anyone of you are experiencing this issue which had been bugging me recently. Occasionally, when I hit the lock button to put my phone to sleep and then wake it up via the same key, the bottom part of my screen (one line) will flash bright white after my wallpaper had already loaded up.
If any of you had this experience, do let me know if there are any ways to fix this... or should I just send it in to the service center?
No0bed
i face tis problem too. but since it is just a small issue, i nv really bother to fix it
silver_frost
Anyone? Email needs to be refreshed manually..
go to setting>display>notifcation panel. u cam shift the sync button up and see if its activated... if you remoce multiscreen button from the top panel. u wont have multiscreen function... try it and tell me if it works for u... cheers
andy_c
The ringtone sometime just doesn't work for call, sms, whatsapp, whatever... and rebooting the device does not solve the issue. It "heals" itself after several reboot and goes into the same problem as and when it like.
Being having missed calls and replying late for important items due to the problem.
Any help is greatly appreciated.
Kooosh
Discovered my Sync button was the cause of this. Didn't know the sync refers to the emails as well. Everything works fine now! Thanks anyway!
shanhz
Hi guys, getting my note 2 today. Should i do an update followed by a factory reset? Will smart stay still b usable? Thats about the only bloatware i am keen about. Tia.
xfiles_wolvie
smart stay is not bloatware...its samsung feature. if u remove all bloatware, smart stay will still stay...cos its smart stay...:s12:
LordDo0m
Guys, just to check, are the usb supplied by n2 and s2 the same? If its the same, the s2 cable should be as efficient in charging the n2 right? Thanks in advance!
renfred89
no not the same. note 2 cable is thicker than s2.
