Samsung Galaxy Note 20 | Note 20 Ultra
DaRRenLieW
Almost 2 week with the phone, Battery somewhat season to my usage .
Finish charging at 5am and bring the phone out at 10am and reach home at 5pm+. Last 5%. Battery definitely a champ!
Lots of gaming and whatsapp , Facebook and music
Sent from Samsung Note 20 Ultra [SD] using GAGT
etoilebiscuit
SD seems to be rocking for gamers. Thanks for your update. Hopefully someone with exynos can update too.
Sent from HUAWEI BLA-L29 using GAGT
Oktechie
Can someone please help? :(
A friend of mine got a Note 20 5G Korean Snapdragon set after I recommended her "the reason why" SD vs Exynos but but she said only the numbers are showing and i feel its on me since i recommended. Names are NOT showing despite being saved and I know in this forum there is mentioned but not for korean phone.
I posted here in the hope that you guys who are more expert can advise on what to do.
The numbers simply do not show . Hope you guys can advise. Did search but can't find this issue to the Korea set.
Thank You.
DaRRenLieW
Thank You.
you need to re key all the contact without the +65 , otherwise migrate to google phone app.
Can be done , need patient
Oktechie
Wahh...I'm not sure I have the patience to be "that" responsible to her lol
I will just tell her to re-key all without + 65 then
I just felt sorry for my recommendation of a SD set if it was going to permanently show number
Thank You very much for your speedy response *feels relief*
nuscape
Deleting +65 is a workaround when you are using SG SIM card.
When she is travelling overseas using temporary overseas SIM card then all those SG contacts without +65 may not work.
Also while using SG SIM if she got contacts from overseas, you need to keep the country code.
Best is may be using Google Phone. Or not sure if Korean set can be changed to use HK firmware?
Sent from Samsung SM-N986B using GAGT
rainydae
Just curious, does your spen (local set) got the samsung word printed there? Mine only got some code number and the word china, looks cheapo. Haha.
Also anyone have issues with google pay? Always got the message - phone moved so fast when i tried to tap to make payment. Read about this online and tried to my sim card into slot 2 but still cannot. Used Singtel Dash no such issues though. Havent tried Samsung Pay yet.
Thanks!
Posted from PCWX using SM-N986B
Oktechie
Thank you for your help. I will convey the message but she does not travel overseas Ever. Yes I know but I don't pry further. Nevertheless this will be helpful to anyone else with the same problem in future.
nuscape
Thanks!
Yes correct. No Samsung logo/ word printed on SPen.
dappercivility
Just got the OP8Pro yet again, will most probably sell off the SD N20U. No 5G for HKG set. Wont want to wait for them to take their own sweet time to push updates. Damn slow
