SAMSUNG GALAXY Note 3 Experience Sharing
Xerovix
i almost fainted when i saw the settings screen. So many features which i dunno to on or off. So many services running in the BG as well
play around the "Data usage" on apps. restricting some apps from accessing or restrict it to wifi only can save battery.
tankib
Yeah I know about the current thing, but the problem you see, I believe it's the bad optimisation between Android 4.3 or Snapdragon S800 eating too much battery while using.
I charged my Note 2 via USB 2.0 cable, it's going up
I charged my Note 3 via USB 3.0 cable, it's going down, slowly
Given the battery capacity difference by only a little, the only way I think it's the Snap S800 eating too much battery, as well as the 1080p screen.
I hate it when I can't charge my Phone via USB desktop, even with USB 3.0...
It a trade off, note 3 size is almost a tablet and cannot use a power that charge a 3.5" phone to charge ur note 3, it take more than 4 hrs, hence have to upgrade the AC charger but can really support using USB port on the laptop.
kyleongwl
I had Xperia Z Ultra which is a snapdragon800.
i do not feel that it is a battrry sucker...play online games as well.
perhaps you could share what you were doing so i could put Nite 3 n Ultra to the same test
For Ultra, it uses magnetic port which could charge a flat phone to full in 1hours....but no sync to PC.
Or perhaps, a usb port v2 could support v3 but slow...just like usb 1 could suppprt 2 but very alow
Jhyun
Tried copying movies to the phone thru USB 3. Blazing fast,so shiok
ronnlim
Notice camera portion bit hot after playing games for 20 mins
Jhyun
The camera focusing part is a major letdown honestly. Hope they fix it soon.
zXioNGz
Hi, thanks for the input, I'm just using it normally like whatsapp etc, but I tried turning off the screen and leave it to charge, the % still stuck at 83% even after 15mins of not using it at all.
I believe Sony got this option to choose, Charging mode or Mass Storage mode right? while Samsung doesn't have this, so we are stucked at 900mA while in Mass Storage mode, whereas USB 3.0 can support up to 1500mA if it's set to charging mode.
PS: The AC charger with USB 3.0 cable is really fast, I just put in for 1-2mins jumped from 83% to 85%. The problem now is Note 2 is charging well with USB 2.0 but Note 3 not charging with USB 3.0
Bapenigo
Firstly, which Telco n where u reside?
why 3G?...shd b using at 4G
What are you trying to do to say its slower...
I am with M1 and staying at chinatown. Even the reception is only 2 bar for 3G and 4G.
Because just 1 days of use with 4G and my data usage is already 139MB.
Was trying to browse hwz and its staggering.
Apparatus
Measure the charging current using the app. If it shows low current then something is wrong with either the cable, the charger or the phone. If I'm not wrong you can do exchange at the shop where you bought from within 3 days if purchase.
carey
GPS on but no app using GPS means no battery being sucked. Only when app using GPS i.e. facebook will the battery level drop. GPS not like wifi. when you on wifi even if not connected to network will suck battery. GPS will only suck when its being used.
Not true leh
I do find a noticeable difference with GPS on and off
Think it's probably cos Android runs a crapload of apps in the background that tap on GPS
carey
What is the normal RAM usage like...
mine was like 1.3gb used... 1.2gb available....
so much usage?
Think Android loads a lot of stuff into the background
I tend to clear my cache once in a while using my Note 2 but a lot less frequently than when I was on S3...hahah
standarture
GPS and WIFI is active all the time one. Maybe you can try and see, if you open your maps, you'll notice that the location is usually always updated. If I on GPS, my battery will drop one. Off GPS and wifi, the phone when screen off, the percentage barely drops.
carey
Location services - i usually off them haha
Xerovix
using android assistant to auto boost the ram every 10 mins:s13:
FuzzyLop
Your location always updated in gmaps cause the location lock is very fast. It uses agps which will use your current cell tower + nearby wifi signal to immediately narrow down your location. Then the calculation for the gps satellite is super fast.
Try this. Off GPS, On wifi, On network location and walk around under your block. Your location would be updated quite accurately even though your GPS is off.
src: http://www.zdnet.com/blog/networking/how-google-and-everyone-else-gets-wi-fi-location-data/1664
http://www.pcmag.com/article2/0,2817,2422689,00.asp
Not true leh
The only app that i think will drain battery in the background are those weather app/widget which try to get your location to download the weather. Or if you use the google latitude service etc. But unless you enable/use those app, it shouldn't matter. GPS battery drains only occur when the GPS is being used. You will know as your notification bar will show. Me i just leave GPS on as it reduces the hassle of manually bringing it on/off.
The most damaging battery vampire are those app that prevent your phone from sleeping or those that keep waking up your phone.
dankoo
Anyone manage to get multi windows to open for 2 instances of same app? I still cannot.
FuzzyLop
Not all app can. Only apps that i so far found out is the samsung browser and google hangout. the rest only 1 window.
