ishoppersmarketing
- May 23, 2012
NO update for mine.
that's fast haha. btw is there anyway to disable the guy speaking while scrolling to different pages?
Hi I have try to root my N7000 to JB, but the Odin prompt me it is fail..i doesnt know why..
<ID:0/005> Can't open the serial(COM) port.
<OSM> All threads completed. (succeed 0 / failed 1)
anyone can help me?
Thank you man.. I hv tried all ways to disable it but no go. I even call samsung service centre but told me maybe software issues and asked me to reset my firmware. That scrolling page voice feedback is really irritating.Do the following.
> Setting, Accessibility, Service, Turn Talk back on.
> Select Setting from bottom of page
> uncheck all talkback option
> Then click back and switch talk back off again
> Go to application manager, Under all Apps, Find google TTS and Samsung TTS
Disable it.
Vola, that guy will not speak when you scroll the page.
Becareful if you are rooting it. You may get a triangle mark. It can be solved by using the triangle away apk software.Can't wait for sg release. I flashed HK JB rom yesterday night,
Was it the correct firmware used or any data cable issue.
By The way,anyone know where to find PPS download file?
Hi Progene, I have completed root HK rom but for speedmod Kernel I never done it, is it possible to skip it or I need to install that??
Speedmod is optional for u since u are already on HKG root.. Go read Speedmod and understand wad it does to see if u wanna change to speedmod Kernel.
