Samsung Galaxy S25, Edge! FE! Ultra! & Accessories ..
What do you think is the nicest color S25 series?
  • Total voters
    202
camoguysg
After using the s25u for few days liao, I noticed a lot of dust trapped easily on the camera lens. Don't know why samsung makes such cheapo lens cover this year...there is a very tiny gap between the ring and the glass so the dust tends to trap there. Even using microfiber cloth to clean cause fibers to trap there....zzzz
Kunkka
Can consider using OneDrive instead of Google. Samsung gallery can sync with OneDrive, ms family (6TB in total) is much cheaper than Google one
Do u then delete the on device file ? Will gallery still show them?
username03
I use alcohol pad instead. Seems better than my microfibre. Anyway I sanitise my phone daily with alcohol pad.
cloudystar
The camera ring is sticked on similar to those 3rd party camera rings as shown by JerryRigEverything.. It can be removed if you use a tool to pry it off.
Those who used to apply the camera rings will be familiar with the gap and the irritating dust issue.
HoGnix
It should be indicated on the parcel that they are not allowed to leave on doorstep. If it goes missing the courier is liable.
On the parcel, only a small letters say Singtel Set, and delivery address. Wrapped with black plastic, never say what is inside and model. I think the deliveryman regards it as common parcel.
DigDub
Remember to set csc code to xsp. Mine was m1.
Alexz_Hong
been using a while... and i normally like CN style of spliting the notifications and quick settings like on HyperOS 2.0 and OriginOS 5.0... but samsung's implementation is.... baffling...
KeYoKe
Eh how to do this again uh, wah damn long ago never see this le, how come yours is m1 CSC?
Your one is samsung store set nt need do la. Digdub korkor should be either get from redwhitemobile, or maybe buy from someone that recontract etc lo
*#272*imei no#
Be very careful when do this, if select wrong, some csc cant roll back one. My friend kena before.
