Samsung microSD card reliable ?
saljiputeh
Visit those shops at Sim Lim Square better if on a budget...
But must know shops to buy from.
Last time I did purchase a sandisk microSD from there and found out that there is no official warranty. Some shops will provide their own warranty and I guess it's okay if you are fine with that :D
koreanlover
Then that shop is parallel imported stock.
xiaowhois
buy Samsung Evo / Pro series microSDHC / microSDXC memory card export set still okay usually if death on arrival usually wont spoilt easily if not Samsung wont give 10years wty
cybercom8
some brands give lifetime waranty also will spoil :o
mosmos
High Honorary Member
i guess have to ask them before buying
ursula
Under normal usage, microSD will last good.
So far (touch-wood), no problem with all my memory cards.
