crystalnox
- Feb 2, 2006
Hopefully they live up to their 5-proof technologies.
It will, cause you will never put your microsd into any one of those situations.
Yes pray that the shop dun fold.
Dont get from small shops. go for those which have been around for years.
Samsung is already the cheapest among high end brands like Sandisk and Lexar.
There are even way cheaper brands (Nitro, Transcend) but currently their max speeds are not on par with the brands above.
On a side note, I was surprised to find out that Lexar is part of Crucial and their products are Made In Korea~![]()
i guess have to ask them before buying
part of the micron...last time some kingston cards were also made in korea
Sandisk got their distributer seal.
Not sure how to check for samsung.
Really¿¡¿ I always thought Kingston's were MIC or MIT~
Under normal usage, microSD will last good.
So far (touch-wood), no problem with all my memory cards.
Yup. Absolutely correct. Some really Want cheap yet kiasee, hard to please
Guess most brands now quite realiable no need worry
So far anyone rma Samsung card already?
i recommend sandisk, samsung as well as kingston. the rest i never bother.
Kingston... Better stay far far away.....i recommend sandisk, samsung as well as kingston. the rest i never bother.
