Samsung Note 10/10+ Accessories Thread
Glariel
Help you answer.
No. They don’t sell.
I asked before for my S10e
Any idea where can get the replacement of the original pre-installed screen protector? Is Samsung selling it?
Sent from Samsung SM-N975F using GAGT
MIVEC525
Whizdom
Hi. If you want a cheaper alternative similar like WSD or etc. Can try okonz tgsp. Just got it installed and able to detect fp . So far so good and able to fit my spigen tough armour
DoraemonBoi
Oh btw if anyone looking for adapter, can try getting the iPad Pro usb-c to 3.5mm one from any apple store. Works perfectly fine with s10+ so should work with note 10 too. Costs 15 bucks I think.
Any idea if we can try it out at apple store? Brought a type c to headphone jack adapter from challenger and it doesn't work...
Glariel
You can go Apple Orchard and test and let us know
Heng I haven’t buy the adapter yet
pipimaster
Aiyo. Forum damn messy nowadays. I see superlengthy post describing a certain tempered glass in every possible way. Machiam advertisement like that. Got heaven got earth. I go paste then the fingerprint also cannot use. Then the shop uncle told me this brand 50/50 chance. What to do? Btw I just gotten Ringke fusion x camo. Damn chio. But a bit rough on the sides.
doki81
Aiyo. Forum damn messy nowadays. I see lengthy post describing a certain tempered glass in every possible way. Machiam advertisement like that. I go paste then the fingerprint also cannot use. Then the shop uncle told me this brand 50/50 chance. What to do? Btw I just gotten Ringke fusion x camo. Damn chio. But a bit rough on the sides.
which one you paste? Wsd?zeelot?
Sent from Samsung Note 10 + using GAGT
doki81
Don’t want to pinpoint la. Not nice. But I think I mentioned till quite obvious le.
If wsd...there is one step on first cute.. need press the fp sensor for 30 seconds...uncle got help you press?
fatthumb
Guys and gals don't buy Zeelot Pure glass. First batch doesn't work for the fingerprint sensor. Made a huge mistake in getting Zeelot, regretting the 39.90 spent.
Thanks a lot for feedback. Almoat gotten this installed at clementi central phone shop also 39$. Will try other brand from neighbouring shop for 30$ :D
*adiBOY
No you can’t test it out.
That being said, you won’t find a better USB-C to 3.5mm headphone jack adapter because of compatibility and DAC.
Circledot
Shop uncle tell you that cause he don't want take responsibility for the mistake he made when applying. Problem with them always like that one, always come up with some excuse to blame the SP rather than themselves.
Whizdom
give a try on okonz
Red_Cheesepie
Wsd staff very nice, make sure can work, good then let you go.. but why keeo trying other cheaper brands to take the risk.. $39 and $60 not much difference in pricing ma..
