Samsung Note 10/10+ Accessories Thread
galaxyuser
Guys and gals don't buy Zeelot Pure glass. First batch doesn't work for the fingerprint sensor. Made a huge mistake in getting Zeelot, regretting the 39.90 spent.
Apparatus
OK, just pasted the WSD and bought the Defense Shield Clear backcase with reflective rainbow color edges from Mobilestop@Northpoint. Total damage is about $100
galaxyuser
Good to take note. The Aukey Amp USB-C Wall Charger supports PD 3.0 AS WELL AS PPS (Programmable Power Supply). This is VERY IMPORTANT to enable 45W charging on the Note10+, without waiting for Samsung's proprietary charger.
Models of AUKEY supported: PA-Y10 (1 USB-C and 1 USB-A) and PA-Y12 (1 USB-C and 2 USB-A; but has extension cord. The main port hub is not directly plugged into the adapter head for the Y12. It is for the Y10.
Red_Cheesepie
Buy WSD.. 2nd day using it.. really good.. make sure they staff help you to paste properly before you leave the store..
Circledot
Have been upgrading my Samsung phone almost every half yearly since the s7 edge and every time I dread finding a screen protector. Since then, I have tried many screen protectors (tpu, pet, tempered glass etc.), and majority have failed me in some way and I ended up spending so much money.
Most screen protectors sold by the small hand phone shops like those in Bugis always charge exorbitant prices for screen protectors that can be easily bought from aliexpress/taobao, and when there is some issue with the screen protector (air bubble, not pasted properly, does not cover entire curve screen etc.), they will always blame the curve edge saying that it is difficult to get a SP that perfectly fits etc. And even if the SP appears perfectly fine at the point of pasting, I always find that I will face some issue on the SP subsequently. Their customer service is great, but i regret to say that their product quality is sub-standard (You pay for what you get anyway, although some of these SPs can be quite expensive too).
Then I stumbled upon this whitestone dome glass, and I initially was reluctant to use it as I scared it will damage my phone and it is quite pricey. But after first applying on my Note 9, I really was extremely satisfied with it and never went back to the other types of SP already. No air bubbles, no sensitivity issue, secure, and feels good!
Either way, the price of the dome glass is relatively cheaper at $50+ as compared to when it was first introduced to SG, and what is the extra few dollars compared to the other SPs when it really save you the hassle of finding a "perfect" SP? Anyway, for my Note 10 I decided to take it 1 step further to purchase it online and apply it myself, and as a first timer, I am really impressed at actually how easy it is to apply it by following the guidance videos they provided, and I manage to apply it perfectly.
So just a tip to all: Just get the whitestone dome glass, really. It may be pricey, and also slightly more expensive compared to the other SP, but i feel the $ is worth it for the hassle free experience and the insurance of not cracking your phone screen when dropped.
Glariel
Yea I also find tempered glass screen protectors since S6 edge and spent $35 for the tempered glass screen protector. It has a lot of sensitive issues end up went back to film.
S7 edge also film, S8+ paste film, after that the film not cover the edge so find a tempered glass one, then come across Whitestone, so pasted Whitestone for my S8+
Thereafter my S8, S8+, Note8, S9, S9+ and Note9 all using Whitestone and never looked back at other screen protectors.
For my S10e, S10, S10+ and Note10+ all use the pre-installed screen protector. My upcoming Note10 also. Heng Samsung got apply screen protector for their this year flagships if not need to spend $60 X 5 devices = $300 :s13:
trenzterra
Anyone tried the Super xfi with note 10? Any issues? On the s10+ it's not compatible and has static issues
Whizdom
Anyone with Okonz Tgsp?
Sent from Samsung SM-N950F using GAGT
trenzterra
Oh btw if anyone looking for adapter, can try getting the iPad Pro usb-c to 3.5mm one from any apple store. Works perfectly fine with s10+ so should work with note 10 too. Costs 15 bucks I think.
nuscape
Any idea where can get the replacement of the original pre-installed screen protector? Is Samsung selling it?
Sent from Samsung SM-N975F using GAGT
Eidekos
plus iphone x xr xs max and xs also bro. u forgot hahahaha
G4
i looking for PA-Y13, but not selling here.
