Samsung Note 10/10+ Accessories Thread
guards80
Just to share with my baseus new 45/60w charger. Can be useful for me to charge my laptop as well. No volt meter reading. The charging is confirm faster than the stock samsung charger.
hmmm any noise come out from the adapter when charging?
wwyjoe
Yup, that’s why I say WSD is still the best
I've installed WSD on my Note 10+, but the touch sensitivty is bad as i have to press down hard for the fingerprint to get recognised (even though it looks well installed). Day to day usage works just fine....
leon0079
Have you tried to enable the sensitivity?
Sent from Note 10+ Glow using GAGT
Tony.Manero
Most of those tempered glass screen protectors either have a hole for the fingerprint or a splotch of glue at the spot... how ugly is it :vijayadmin:
Tony.Manero
My advice is just stick with the out of the box screen protector and use it until you find plastic ones or glass ones that doesn't have that ugly hole or splotch of glue.
Tony.Manero
Ok. The ugly splotch of glue at the finger print area does become uniform circle after a day but it's still very obvious when the screen is off. As there is no adhesive at the rest of the screen except the edges, the black seems grayer than without the tempered glass screen protector. This might suit many people but I prefer my screen to have that darker tint. Will switch back to plastic screen protectors when it arrives
Glariel
If change S Pen, other than remove the old S Pen and slot in the new S Pen, need to do what? Anyone know from previous Note devices?
xominon
The USB-C 3.5mm adaptor is avaliable already at Plaza Sing Samsung shop....
Got it just now, $28
Sent from Samsung SM-N975F using GAGT
lussypicker
supcase used to have case with built in screen protector. but note10 plus now comes with screen protector and fingerprint scanner on screen so they removed it. anyone have any case with built in screen protector to introduce?
i don't use fingerprint scanner anyway.
