Samsung Note 10/10+ Accessories Thread
Glariel
They have to cut out so as the camera will work properly
looking for film. So far zeelot not very good experience. Previously was using on S10 but fingerprint always end up no good. And it will bubble on the sides after a few days.
My wsd currently looks as good as new. If only they choose not to cut out that stupid hole...
I'm also looking for a place that sells clear rear protector for the phone. Any suggestions?
Eidekos
Im using PA Y10 aukey one. It supports 45w charging.
from 10% if i use the pay10 it shows 53 mins to full charge... but if i use the default boxed charger its shows 1hr and 23 mins to full charge.
I always charge bfre leaving work for 30 mins screen off. gives me 60+% after 30 mins
Sent from Samsung SM-N975F using GAGT
kacang2
Just managed to get note10+ today. Based on the comments, Whitestone Dome seems to be the best screen protector to buy. Any idea which case will be compatible with WSD?
tutonic
If you really value the responsiveness of your in display fingerprint scanner, you'll stay away from tempered glass SP. You should learn from the experience of S10 users, since the scanner is the exact same one.
kacang2
I see, in this case, which screen protector is recommended ya?
tutonic
If you don't want to read through the s10 threads, the gist of it is simply the following:
ALL tempered glass screen protectors CANNOT get same level of responsiveness of the fingerprint scanner. At best, you'll get 90-97%, for example.
If you use the pre-installed film protector, you'll get something like 99.9% responsiveness. Most of the 3rd party film protectors will also get you that same level of responsiveness, so no real need to rush to get a 'better' one since not much difference, in my opinion.
If you're using film protector and not getting very high accuracy, it means you've incorrectly registered your fingerprints.
If you're fine with the scanner working most of the time, then you're free to get tempered glass SP. But whenever it fails to unlock, or when you need to authenticate (for payment or whatever), I tell you, really damn annoying and frustrating..
MIVEC525
jnashville
I am about to buy the note 10. The pre installed film protector = you mean samsung provide a screen protector inside the box?
nuscape
The plastic film screen protector already applied to the phone from factory.
outrun100
Not sure if anyone share this before...was told by samseng FB they not bringing the travel 45W charger
Hi Kenny, thanks for your interest in the 45W charger. After careful consideration, we regret that we will not be ranging the 45W charger in Singapore. Galaxy Note10/10+ customers can continue to enjoy super fast charging with the 25W charger provided in the box. We seek your kind understanding and we're sorry for any inconvenience caused.
trenzterra
It's already placed on the phone itself.
I tried both Whitestone and zeelot for note 10.
Whitestone -- fingerprint response seems better. But this seems to be at the expense of overall touchscreen sensitivity -- need to enable increase touch sensitivity in settings. Glass does not cover the camera cutout and the area above and surrounding it.
Zeelot - full coverage, touch screen sensitivity is good. Fingerprint response not so good when hands are dry. Glue at the edges seem to be peeling more quickly.
The only issue I have with film protectors now is clarity. The in built screen protector has a little bit of matte coating, which I don't like.
teoph04
I 2nd this. WS seems to be of better quality overall. My zeelot always peel at the sides for S10 n Note 10, have you tried Okonz?
Aicirt
ordered ringke film 2 pack frm shopee.. dont want to go TG route again. *********
Looking forward to your review. I'm looking at that 2 film back and front pack as well....dont know why they dont offer full coverage anymore since note9. S10 this year also no full coverages.....
hippo1n2
This is my zeelot … its side is all bubbles and somehing like cracks… annoying ! Sometimes the white loca glue will stick on my case
Sent from Nokia 3310 using GAGT
haohaoz
Hi
is there any reason they not brining the 45w to sg ?
i read as samsung required PPS on top of PD charging , how about aukey or baseus charger i saw it has PPS ?
trenzterra
I tried before on s10. Took it out one day later. The screen protector was a bit too long or something, can see a lot of glue at the side of the screen so the sides look ugly as well. Not sure how to explain cos I don't have a photo anymore. Fingerprint sensor wasn't any better than zeelot even though the guy kept insisting his was better.
Quality wise I would say wsd > zeelot > okonz. But s10 wsd had issues with the fingerprint and spiderwebbing.
Wish Samsung could come up with their own range of tgsp haha
trenzterra
Hi
Aukey works well for me. Not 45w but faster than the 25w charger. My first pa-y12 was a bit faulty cos it charged slower than the 25w charger (anyone wanna buy from me? Still works fine on normal pd devices). Bought another piece which works just fine.
Tony.Manero
I bought amfilm. Similar but cheaper than whitestone
Whizdom
Hooted uag plasma. Now got two casing spigen tough armour and this
Sent from null using GAGT
