Samsung Note 10/10+ Accessories Thread
Tsting
Do these branded cases come with those lanyard-like holes? Wanna add a hand-strap to the case
xenocide
Anyone know where got sell Note10+ case under $10?
usually those push cart should have those cheap silicon case for about $8. just have to ask if you happen to walk past 1.
Ringke has holes for lanyard so far i've seen
Whizdom
heard from those under block shops that certain TGSP , cant use fingerprint due to sensitivity issues.
Glariel
I don’t like silicon cases. It attracts a lot of dust. I prefer those rubber kind one, some more it’s only my temporarily case until I get RS. I also don’t want to spend so much. Max I will go for is $20. If can under $10 will be the best.
Last time when I first bought my S10+, my temporarily case only cost $6 before my RS come which is like 2 weeks.
Whizdom
Is it worthy to get camera screenprotector? Anyone tried before? Hows the performance and quality with screenprotector on
Sent from Samsung SM-N950F using GAGT
Tony.Manero
Nillkin-Synthetic-fiber-Carbon-Back-Cover-Nylon-for-Samsung-Galaxy-Note-10-case-thin-slim-for.jpg
doki81
If you use case...no need buy sp for camera...will definitely affect cam quality...
Sent from Samsung Exploding Not 9? using GAGT
Glariel
I never put any screen protector on my phone camera before :D
Tony.Manero
I'm upgrading because it seems so light for the size. I hope the casing not going to make it feel heavy again:(
