Samsung Note 10/10+ issues
lifeinmono
can't use Samsung Dex with the cable provided.
it was okay but now not okay.
how come ah
aw1007
You need to get your fingerprint RAW first ie without any screen protector on. This includes removing the original plastic film screen protector.
After that paste your screen protector and test fingerprint again. WSD works well in my case
Would it be heavy after WSD installation?
Sent from Samsung SM-N975F using GAGT
xenocide
how come ah
win10 or win 8?
i'm using Win8 and sometimes it does not detect also
need to unplug and plug back USB cable
Aikon
Note10+ feels faster and does not require as much pressure as S10+ needs
a small tap, it will unlock.
on the S10+ i need to press down my thumb
I guess it's different for everyone. Got very dry hands, can't detect on note 10. Rub some Vaseline, can detect much better... Not practical..
Maybe it's the screen protector from Red White mobile.
Aikon
Fussy doesn't accept my Elecom USB C audio adapter. No problems it working with the P30 Pro and OnePlus 7 Pro though.
Got to fork out money to get another adapter. šŸ™„
xenocide
ya cannot be dry. if i am in air con room, when my thumb is dry, success rate is low also. have to "borrow" oil from my face :s13:
Glariel
Not really. It’s the phone.
My hands dry also cannot detect, got some oil then can detect. Using the original film protector
galaxyuser
My Note10+ phone the battery health 40.2% sia wth.
Is it a cause for concern? My battery drains like 1% every 5 minutes...
micshang
Hi, I tried to reset my CSC. I keyed in *#272*imei#. I received the following error message, connection problem or invalid MMI code.
I keyed in the 2 imei no and both I get the same error message.
Can any expert here advise what is the issue? Many thanks
chooyoshi
Certain phone cases can interfere with the spend, causing the phone to think that it is detached. Hence I paid 78$ for the official flip cover.
Glariel
I don’t like flip cover
I have enough of it for my Note8 and Note9 :s13:
JAson1980
Anyone have the super xfi amp and using with note 10? On the s10 there is a bug that causes cracking noise every few seconds on this amp as well as a few others. Wondering if it's the same for the note 10
Update your amp?
Glariel
Update your software?
Snoweagle
Already updated when the phone is out of the box.. Could it b bcos JB set? Must take out sim card?
I also took the opportunity to update at the SES when my Note9’s being assessed for trade up.
IAmARobot
Does anyone have issues between their SD card and S10+?
Phone able to detect other SD cards but not one of the Sandisk SD card. Sandisk SD card seems to be working as my computer was able to access that SD card. Tried formatting the SD card but didn't solve the problem.
Glariel
This is for Note10 not S10
