Is it my phone or is it all the same? When play video or what using phone speaker the back of the phone near the camera will vibrate according to the sound. It like a echoing rebound and causes it.
It from the top speaker
Samsung needs to fix the Note10+ software fast enough.
Sometimes when I plug in the USB-C Cable into the port, I get an error message saying "This USB connector is not supported". I believe it has something to do with the system software rejecting the charge. Whenever I restart, the problem automatically goes away.
I never encountered this issue. I’m using my previous Note9’s fast charger.
UPDATE: Found out from the Samsung Plaza Singapura Service Centre that a new charging protection mechanism has been introduced with the Note10 and 10+. Such that only one side of the reversible type C connector will be recognised to avoid causing accidental damage to the phone's port. Only insert into the port the side of the type C with the ridges on the type C connector itself. Photo below.
On Type-C cables that don't have the ridges on either side, it will be a trial and error. Rest assured that only the phone port to type-C connector is the concern here. Plugging any way on the charger side doesn't matter.
Failure to insert the right way will sometimes cause the phone to prompt up a message saying "This USB connector isn't supported."
"Will take my set to Vivocity soon." (Old comment)
