Samsung Note 4 Mobile Data Slow Connection
IAmZTX
Hi all,
I have some issues with my newly bought note 4. Usually when we connect to Mobile Data. The connection to mobile data is immediate, in my current plan which is 3G. It takes about 30-50 seconds to connect to 3G. This is very unusual because i have to wait 30-50 seconds just to connect to 3G.
I went down to Singtel Shop to replace for a new SIM card. It does not solve the problem.
Anyone here can have the same problem as me?
FYI: I am able to connect to 3G and surf internet, play games as per normal. Just that it takes time to connect to 3G which is abnormal.
zXioNGz
Actually I also feel Note 4 atenna not as good as designed on Note 3, at the same places, mostly 4G on my Note 3 and my friend's S5 but Note 4 will show 3G or just H/H+.
Same thing on my Sister's Note 4 so I guess it might be design issue.
renfred89
I think its the algorithm issue rather than hardware design..
IAmZTX
If it is the software issue, still can feedback and they might launch a firmware upgrade. If not software issue then LLST already.. USB 3.0 to USB 2.0 already a turn off.. If mobile data connectivity also another problem..
Product failure man
Yurikaze
First world problems. Haha.
By right connection should be immediate. Perhaps you on 3G similar need some time to connect?
4G network here. Almost instant connection with juice defender ultimate. Once cut off, it's immediate.the connection kicks in when screen is on.
daylight
i also noticed that the note 4 take some time to get connected when i switch to mobile network.
it was almost immediate when i was using note 2 before.
