Samsung Note Edge
Yellow_Duckie
Camera issue
Hi
Any edge user having prob with e camera unable to focus? It's taking blur pics?
Help needed please..
SExiao
Hi
Same prob.... Just give it sometime or go into setting...give a while it will work.... Weired problem... Hope they fix it on next firmware....
Edited... Okay done some googling... Apparently there is a plastic cover on the lens... Remove it and problem solve.... Not easy to spot... But it's there....
Yellow_Duckie
I called up samsung hotline the guy got me to clear cache n cookies and it works! Make me worried the entire noon as I can't use e cam :(
derrickgoh
Guess the price scares ppl away. My colleagues are also impressed by the one piece of glass which functions as 2 screens. Ok the ruler is a little lame but i love how when i am browsing the net or watching video the notifications are on the small screen.
kero89
It's like Samsung philosophy of multi tasking, started with multi window and slowly becoming a "always there but not annoying and yet so awesome" shortcut and notification screen.
boaboy
Any idea whr to get full screen protector including the edge ? Having difficulty arghhh
0400392G
P2o mobile burlington square, simei handphone shop, Redwhitemobile. Their brands are healing shield
trd2970
Im also impressed by the side screen but when I tried on the demo unit I get a lot of accidental pressing of the side screen buttons.
skaade
anyone here that moved from note 4 to note edge? I'm curious to hear from people who've made the switch and their experience so far.
angel99999
It feels alright once u have a Casing on. And I suggest going with a casing as the grip is not as firm as a Note 4 due to the thinness of the right side and also fear of accidental touch.
benny888
I used the Note 4 for a month before switching to this Note Edge
Performance wise not much difference
Only obvious advantage of Note Edge is the EDGE which I find very useful
The Edge is still basically a NOTE4
BTW both my phones are Exynos Octacore processors : Note is Malaysian model while the Note Edge is Korean
petricnah
How do you find the Edge battery life as compare to Note 4?
Sent from GAGT Android App
nightkids7089
so is the Exynos processor performing better than the Qualcomm ? :(:(:(
wiccawizzards
Happy 2015 everyone!
Oh the HWZ ah, now tempting me with advertisements for the Edge.
Hmmmm, would anyone agree with me if the Edge was actually the top part of the Edge instead of the right side?
royfrosty
Nah, the edge feels much more better on where it should be right now.
It is DARN useful. I find my shortcuts damn easy to navigate.
Drawer apps are just too mainstream already. The EDGE makes it easier to access.
Btw i have applied Skinomi screenguard. So far my experience on it is bad.
nightkids7089
frankly speaking, i don understand why the need to put screen protector? :s11:
isn't the screen made of simi gorilla glass?
scratch proof?
putting screen protector will not lessen the screen's sensitivity meh ? :s11:
